Old 08-01-2010, 10:02 PM   #1
mooseknuckles
mooseknuckles's Avatar
serp swap
I'm thinking of doing a serpetine swap on my '86 305, I have the whole set up off a '90 v6 w/ac. can I run the setup with the ac comp on there without it hooked up? just free wheeling? cause I don't have air cond on my truck. would it ruin the compressor? I would like to have a/c someday when I find a donor. but for now I need the compressor on there for propper belt length, and I can't get the bolts out without taking the clutch off the compressor and it would look stupid without it.
mooseknuckles is offline   Reply With Quote
Old 08-01-2010, 10:05 PM   #2
cableguy0
Re: serp swap
If the system stays open for a long period of time the compressor will not be anygood anyhow. I have just left the compressor to freewheel in the past. There is also an a/c delete pulley available for about 35 bucks. Amazon.com: Dorman HELP AC Bypass Pulley 34157:... Amazon.com: Dorman HELP AC Bypass Pulley 34157:... . You should be able to get the bolts off. Its a tight but definately doable.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-01-2010, 10:22 PM   #3
mooseknuckles
Re: serp swap
If the system stays open for a long period of time the compressor will not be anygood anyhow. I have just left the compressor to freewheel in the past. There is also an a/c delete pulley available for about 35 bucks. Amazon.com: Dorman HELP AC Bypass Pulley 34157: Automotive . You should be able to get the bolts off. Its a tight but definately doable.
thanks.
Old 08-01-2010, 10:29 PM   #4
joe231
joe231's Avatar
Re: serp swap
If you look at the compressor bolts they have one flat side that will just barely slide past the pulley/clutch to allow removal of the compressor with the pulley/clutch intact.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 08-01-2010, 10:39 PM   #5
mooseknuckles
Re: serp swap
I thought I looked for something like that, guess I'll have to look again. or make my own "flat spots". thanks.
