Old 08-08-2010, 11:55 AM   #1
LennyGB53
Chassis Number
Does anyone know where I would find the chassis number on my 1969 C10 SB?
LennyGB53 is offline   Reply With Quote
Old 08-08-2010, 12:15 PM   #2
vectorit
What?
vectorit's Avatar
Re: Chassis Number
If you are referring to the number that corresponds to the VIN, then it is typically on the frame next to the steering gear on the top.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-08-2010, 12:20 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Chassis Number
but not all frames got stamped for some reason.
Old 08-08-2010, 12:25 PM   #4
burb71
Active Member
Re: Chassis Number
If you are talking about the unit #, the one that macthes the vin mine is on the top of the driver side frame rail next to the rag joint on the steering rod
burb71 is offline   Reply With Quote
Old 08-08-2010, 12:34 PM   #5
Shyguy
Junior Member
Shyguy's Avatar
Re: Chassis Number
Yep, that is where mine was, but for some reason or other it disappeared with a piece of the frame before I bought it.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-08-2010, 01:09 PM   #6
bruceman1968
bruceman1968's Avatar
Re: Chassis Number
Here's a pic of it on mine.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 08-08-2010, 02:16 PM   #7
grs
Re: Chassis Number
My frame does not have a number on the frame anywhere. It was built in Calif. Did Calif. truck frames have a number on the frame?
grs is offline   Reply With Quote
Old 08-08-2010, 03:19 PM   #8
burb71
Active Member
Re: Chassis Number
My 1968 truck was built in Fremont, Ca "Z" it has it.
Old 08-09-2010, 11:28 AM   #9
dfwright
dfwright's Avatar
Re: Chassis Number
My chassis actually has the number stamped in two places. At the front by the power steering pump area as already mentioned, and again further back under where the cab rests, near the rear cab mount area.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 08-09-2010, 12:37 PM   #10
LennyGB53
Re: Chassis Number
I'll look when we switch cabs. Good luck on yours. I know how it is with this one. My last one, a 1968 C10 was a Texas truck and didn't need nearly this much reconstruction. This one had so much mud packed in the upper A-Frame the openings were completely filled. While replacing the steering gear I took out a bolt and it pushed through with a piece of the frame attached to the bolt. Sigh...
Good luck and thank you again. I'm going to look to see if there's a number on the differential today.
