08-21-2010, 12:04 PM | #1 |
To or not to run a rear end Sway bar
Anyone run one? If so Why, Why not? Im thinking of getting a weld in one.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
08-21-2010, 12:11 PM | #2 |
"the other guy"
Re: To or not to run a rear end Sway bar
I installed one from a 85 iroc, havent had much street time but so far it works GREAT!
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" |
08-21-2010, 12:16 PM | #3 |
Hollister Road Co.
I have one on my 72 C10 LWB, made a big difference in how it handles and tows
08-21-2010, 12:48 PM | #4 |
I've often thought about installing one. The guys at ECE advised me against it. They said the stock trailing arm suspension with panhard bar is pretty stiff to begin with.
If I were to install one, it would be a Hotchkis setup.
08-21-2010, 01:38 PM | #5 |
I had one from ECE and once I replaced my trailing arms with the arms from Early classics I took it off as they advice me against it....I do have the front one from ECE and it works like a champ. The back one worked great with the old stock trailing arms.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
08-21-2010, 01:53 PM | #6 |
I have one on the rear from a LS1 camaro.
However, I recently read an article (I think someone one posted it on here) where some magazine did some testing and got better slalom times without a rear bar. However, the rear sway bar can be used for tuning the suspension depending on the size. Too large of a rear sway bar can induce oversteer. Yet having a large front bar and no rear bar may cause additional understeer (I assume that a front end heavy pickup will have understeer pretty much regardless). So if you have a large front bar, a small back bar may help a little. It would also help with towing and drag racing as well. |
08-21-2010, 03:51 PM | #7 |
i ran a helwig rear bar with stock front bar// was excellent for long distance towing and with very high heavy loads in the bed// truck handeled excellent both loarded and empty would do again without hesitation
i think the norm is rear should b 2/3 diameter of front bar for proper balance
08-21-2010, 06:36 PM | #8 |
Parts and more parts
I have one on my 84 GMC SWB and the install made a difference on that truck. It gives a more positive grip to the ground compared to the somewhat sloppy ride it had before. when I put the 68 together, I am seriously considering a bar on the back of it.
Frank |
08-21-2010, 07:08 PM | #9 |
I really do not like my rear end bounding over every little bump. This and i would love it to corner better. I looked at my set up and what i want to do as far as Coil overs in front of the Axle. I will probably go with one that welds up between the rails and drops to the top of the axle. Like the Competition Engineering ones.
08-21-2010, 10:02 PM | #10 |
I can corner with some of the best cars, now that I have updated my rear end.
Frank |
