Old 09-09-2010, 01:41 AM   #1
kikkegek
kikkegek's Avatar
what is the correct oil pressure for a small block
I have been driving my Burb for about 4 months now. I noticed that the needle for the oil pressure is at about 15-20 (in the middle of 0 and 30) all the time.
So after a cold start, running idle, running 55 mph and when the engine is warmed up, the needle always seems to be in the same place.
so three questions:
1. is 15-20 OK? (is this psi of mbar or what?)
2. shouldn't the needle move when increasing rpm's?
3. should there be a difference in cold and warm oil pressure?
kikkegek is offline   Reply With Quote
Old 09-09-2010, 07:47 AM   #2
BigBlocksRule
Re: what is the correct oil pressure for a small block
10psi per 1000 revs is pretty much the norm. I don't like mine to drop below about 25psi at idle, though.
I'd check the gauge first. You're right, pressure should be higher when cold (thicker oil = more resistance to flow) and should increase with rpm's.
BigBlocksRule is offline   Reply With Quote
Old 09-09-2010, 08:00 AM   #3
kikkegek
kikkegek's Avatar
how can I check the guage? can I measure volts or Ohms to see if it is working correct?
Old 09-09-2010, 08:41 AM   #4
Seven9er
Seven9er's Avatar
factory gauges aren't really that accurate. they give you a good estimation but are not spot on. An engine needs at least 7psi to run. 14.7psi=1bar. You will be fine with what you have even at cruising speed 15psi is enough. If you still have quals about it install an aftermarket mechanical oil pressure gauge. Ye you have to run an oil line into the cab but if you protect it you will be fine. Thats the best way to see what your running. You can always replace you factory oil pressure sensor for a more accurate reading. Once you start getting 10psi at idle then look into a rebuild, most likly will be main bearings or cam bearings. at that point you might even get a little lifter knock.
USMC Former SGT 2002-2006
Oshkosh Truck Corporation- FSR, The worlds largest manufacturer of Severe Duty Trucks.
The Money Pit. http://67-72chevytrucks.com/vboard/s...d.php?t=406891
2009 2500HD R.I.P. http://67-72chevytrucks.com/vboard/s...12#post4025612
Seven9er is offline   Reply With Quote
Old 09-09-2010, 01:20 PM   #5
PRattenbury
Run it till it pukes.
PRattenbury is offline   Reply With Quote
Old 09-09-2010, 01:34 PM   #6
irishman999
irishman999's Avatar
I got a cheap mechanical gauge set at orileys for around 30 bucks, im very pleased with it!
irishman999 is offline   Reply With Quote
Old 09-09-2010, 05:14 PM   #7
kikkegek
kikkegek's Avatar
oke,
thanks guys! all great solutions, but I would really just like to check the original guage or check the voltage or ohms at the connection of the guage.
I got the voltmeter laying around and here in Europe it is not that easy to get parts like you can in the USA.
hope somebody can help me with this question on volts or omhs?
Old 09-14-2010, 04:04 PM   #8
kikkegek
kikkegek's Avatar
Originally Posted by kikkegek View Post
oke,
*bump*
checked my oil guage during last ride:
when ignition on and engine off: 0
when engine on: 15
when driving: 15
when idleing: 15
isnt that strange
thats why I woud like to check it with a volt or ohm meter. please advise
Old 09-09-2010, 04:39 PM   #9
3r!c84
Badass
3r!c84's Avatar
Mines at like 30 at idle and mazes out at 80 sometimes..
I got a stock 0-80 gauge
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-14-2010, 05:53 PM   #10
3r!c84
Badass
3r!c84's Avatar
Maybe a bad sender
-00 Saturn 5spd
1/4:13:90
