09-13-2010, 09:53 PM | #1 |
3/8" 24 square weldnuts
guys need a source for these: 3/8" 24 square weldnuts. i can find 3/8" 16 all day long. fixing the lower door hinge pocket on my 56' panel. i realize for $88 bucks delivered i can purchase repair parts but i'm not gonna cut up the doors when i can build a 2"x4.5" plate and weld it in to fix issue with doors. these are not "caged nuts" those are different dogs. thanks.
09-13-2010, 11:20 PM | #2 |
Hollister Road Co.
Re: 3/8" 24 square weldnuts
You maybe better off buying flat stock and making your own. Onlinemetals.com is in your neck of the woods or speedymetals.com will sell you small pieces at reasonable prices.
09-14-2010, 01:26 AM | #3 |
I couldn't find any with enough movement to adjust the doors. If you scroll down to post #117 and you can see what I did. You do have to hold them from behind but once they're in they work fine.
Kim http://67-72chevytrucks.com/vboard/s...=283107&page=5 |
09-14-2010, 02:01 AM | #4 |
thanks! so what your saying is you left them as "floaters" instead of welding them to the door lower hinge pocket mounting plate. great idea and i wouldn't say you were cheap just have seen the reality of "sub-standard" replacement parts that require as much time fitting them as you would take making your own. these days i tell anyone building these trucks when they are thumbing through a wish book (catalog) that the only thing that bolts on "is a wheel!"
09-14-2010, 08:37 AM | #5 | |
Kim |
09-14-2010, 09:35 AM | #6 | |
09-14-2010, 10:33 AM | #7 | |
Kim |
09-14-2010, 03:29 PM | #8 |
the area that i'm having issue is on the door in the lower hinge pocket so i'll be welding them solid like they were factory as the door hinge has plenty of adjustment. i do like the idea of using countersunk rivets to hold them in place. my hinge pockets in the door jambs are in good condition thankfully but i think using kims idea using "reinforced" nut plates will work great later on. thanks guys!
09-14-2010, 05:07 PM | #9 | |
Kim http://67-72chevytrucks.com/vboard/s...=283107&page=4 |
09-14-2010, 06:30 PM | #10 |
Mar-K has them. Just make sure you get all of the galvanizing off of them before you weld them to the hinge pocket.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
09-14-2010, 04:05 PM | #11 |
guys here is a link to a supplier for 3/8 24 "square weldnuts", same ones used on the reproduction parts your buying. http://www.on-b.com/nuts/dek-4.aspx
09-15-2010, 01:51 AM | #12 |
got some ordered today from ohio nut & bolt and these are plain steel. i will post some pic's comparing the reproduction parts and the ones from ohio nut & bolt when they arrive.
09-18-2010, 01:04 AM | #13 |
wanna see those on ur project...
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks ) 54 caddy 62 series 4 door(younger sons ride, aka 54caddy ) 70 caddy 2 door, 89 chevy silverado stepside(older sons rides ) |
09-18-2010, 03:23 AM | #14 |
got the rest of the door apart tonight and need to drill out the leftover cut off screws that held on the metal door panel, gonna use some heat and a left-handed drill bit. i will post some pic's of the weld nuts on the new repair panel for the door. door will be much easier to hang with the weight of the window removed. window regulator is in good shape with exception of the nylon rollers, who sells them?
09-19-2010, 03:08 AM | #15 |
the 3/8" 24 "weldnuts" showed up today so we can start on the door repair. they look exactly like the ones they use on the reproductions repair parts.
09-19-2010, 09:13 PM | #16 |
waiting to see......
09-20-2010, 02:17 AM | #17 |
here are the 3/8" 24 "weldnuts" i was sent. they are exactly like the ones on the reproduction parts.
