Old 10-26-2010, 08:56 PM   #1
my69camaro1
Young One
Question 6.2L Diesel White Smoke?
Finally got a 1984 M1008 pickup running this past weekend that I purchased a few weeks ago. Had been sitting for at least 2 years. Half of the glowplugs are dead and it needs a quick shot of either to start when cold. Injection pump under intake leaks...
Anyway, the drivers side exhaust has a light haze at idle once the truck has warmed up. Light puff when first started then it goes away for a few min until warm. Punch it when warm and a large cloud will shoot out until you let off.
It was real bad when I first got it running but has gotten better the more I drive it. No smoke out pass side. Seems to drive fine, and motor power seems comparable to my past 6.2L trucks.
Doesn't look to be using coolant and the oil is clean.
69 R/S Camaro
79 K5
86 M1008
11 P71 Vic
12 Ram 3500
18 Ram 2500
my69camaro1 is offline   Reply With Quote
Old 10-26-2010, 09:14 PM   #2
palposity
palposity's Avatar
Re: 6.2L Diesel White Smoke?
Early Duramax engines had similar symptoms when the injectors were going bad. Another symptom was diesel fuel in the crank case. Older diesels don't like newer ulsd fuel - not enough lubricity. I typically add 1/3 of a bottle of Amsoil diesel concentrate with each tank of fuel on mine.
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline   Reply With Quote
Old 10-26-2010, 09:16 PM   #3
87 V20 Scottsdale
87 V20 Scottsdale's Avatar
I'm guessing it's one of the injectors.
Andrew
1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10
1988 C1500 Scottsdale 305, 700R4, 3.08
1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10
87 V20 Scottsdale is offline   Reply With Quote
