Old 11-01-2010, 01:50 PM   #1
smokinstang70
smokinstang70's Avatar
Chassis paint and primer
Looking at painting my Chassis next weekend. Ihave pressure washed the entire chassis, control arms, and crossmember... sent them to the sand blaster... and will be getting it back on Friday. What chassis paint do you guys recommend. Not making a show truck... want something that will be durable.
How much paint and primer will it take?
smokinstang70 is offline   Reply With Quote
Old 11-01-2010, 01:59 PM   #2
mwilliams5891
Re: Chassis paint and primer
hey just curious about how much was it to get it sand blasted?
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56
-03 Mazda Protege 5
-WTB 1970 Chevelle project
mwilliams5891 is offline   Reply With Quote
Old 11-01-2010, 02:09 PM   #3
Lee H
Lee H's Avatar
I've used rustolium satin black and Eastwood chassis black with good results. Both rattle can and easy to apply. I've tried por 15 and the results where disappointing for all the hype and expense.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 11-01-2010, 02:31 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
I used rustoleum primer and hammered finish black and accents in silver on my last frame. I like the texture it creates....similar to a silver vein powdercoat. With a frame that might need holes drilled in it and might get scratched I think it makes sense. It's easy to touch up if damaged also. I will be spraying another frame this week with it.
Old 11-01-2010, 06:48 PM   #5
mikey531
mikey531's Avatar
VA72C10
Could you post some pictures when you finish?
mikey531 is offline   Reply With Quote
Old 11-01-2010, 09:50 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by mikey531 View Post
VA72C10
I can do better...here is the old frame and components....
Old 11-01-2010, 10:52 PM   #7
ebry710
What a beautiful work of art. Nice job.
1971 Chevy C-20 Flatbed SBC350/Turbo 350
"Torque Is Controlled Power"
ebry710 is offline   Reply With Quote
Old 11-01-2010, 08:15 PM   #8
my67c20
I went with Eastwoods Extreme Chassis Black Primer, then hit it with a scotch brite then 2 coats of the Extreme Chassis Black Gloss. Easy to work with covered good. It a heavy solid paint so anything you don't want overspray on i recommend you cover it. Don't get too close or it will run. The other parts i hit with the Silver Cad products.
my67c20 is offline   Reply With Quote
Old 11-01-2010, 08:23 PM   #9
Hubscrub
Cruzin
Hubscrub's Avatar
i have used rustoleum and eastwood paint on mine and they are about the same the rustoleum is much cheaper and you can buy it local when as you have to order the eastwood and pay shipping i sprayed both from a paint gun
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 11-01-2010, 08:31 PM   #10
gopokes
gopokes's Avatar
I used KBS rust seal, brush it on and it levels out to almost look like powder coat. I read awesome reviews and the finished product was great. Only took a quart for two full coats, even enough for the rearend. I think it's only around $35 for a quart.
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224
gopokes is offline   Reply With Quote
Old 11-02-2010, 05:32 AM   #11
mikey531
mikey531's Avatar
Well you just showed me what I am doing all winter ! Awesome !
Thanks !
Old 11-02-2010, 12:10 PM   #12
VA72C10
VA72C10
VA72C10's Avatar
Thanks guys
Old 11-02-2010, 01:39 PM   #13
smokinstang70
Thanks for all the advice and options... its a lot to think about. Like I said, I just want to do this once... have a durable finish... and move forward.
Thanks again... you guys are awesome.
Old 11-02-2010, 07:53 PM   #14
grs
Has anyone ever painted there frame with engine paint?
grs is offline   Reply With Quote
Old 11-02-2010, 07:57 PM   #15
tim21391
tim21391's Avatar
we use chassis black i think its from duplicolor from o reillys we use that in the body shop
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
