Old 11-05-2010, 01:29 PM   #1
snj8198
snj8198's Avatar
Fan shrouds
Hi guys,
What's the difference between fan shrouds? Are they classified by big block small block or by short and long water pump assemblies? The one in my truck broke a bottom ear off and had an unfortunate meeting with the fan going down the highway. The depth dimensions on mine are 5 1/4" top and 5 3/4" bottom and i'm using it with a long water pump on my bbc.
Thanks -steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 11-05-2010, 02:21 PM   #2
burb71
Active Member
Re: Fan shrouds
Factory Big Block Trucks has its own shroud.
Small block trucks has one for factory A/C trucks, one without A/C, one for 4 Wheel drive.
Chevy in line 6 cyl have just a metal topper shroud over the fan blades.
GMC V6 have a full shroud as all the other trucks.
The GMC 6 cyl shroud & one of the small block shrouds may be the same.
burb71 is offline   Reply With Quote
Old 11-05-2010, 03:00 PM   #3
snj8198
snj8198's Avatar
Re: Fan shrouds
well crap im not too sure what i have then. thanks for the info Burb. how do i order a new one? just by dimensions? i need to get my info straight so i now what to ask or look for in the for sale forums.
Steve
Old 11-05-2010, 03:29 PM   #4
burb71
Active Member
Re: Fan shrouds
Post a pic of your shroud, anyone on the board can tell right off its a big block shroud.
If its not a Big Block shroud someone on the board can I.D. it.
If not get the part # off of it, its on it somewhere you just need to find it and you will know what you need.
Old 11-05-2010, 03:59 PM   #5
snj8198
snj8198's Avatar
Re: Fan shrouds
6264137 CVT4
mean anything to ya?
Steve
Old 11-05-2010, 04:03 PM   #6
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Fan shrouds
looks like a 4wd shroud to me.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-05-2010, 04:09 PM   #7
my67chevytruck
Under Construction
Re: Fan shrouds
here is a BBC shroud
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 11-05-2010, 04:34 PM   #8
snj8198
snj8198's Avatar
Re: Fan shrouds
ok then it looks like i need a small block shroud. i'll search around for a pic of to make sure it matches mine. thanks for your help guys.
much appreciated, -steve
Steve
Old 11-05-2010, 07:40 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Fan shrouds
The shroud on my 4x4 measures about 9" deep.... I'd guess that one's from a 2wd.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 11-05-2010, 07:59 PM   #10
71swb4x4
71swb4x4's Avatar
Re: Fan shrouds
Looks like a 4wd shroud to me too.
What engine do you have now? If it's a small block, is it in the factory small block 2wd position? Sometimes when people replace a 6 cyl with a small block they put the small block in the back position, if that's the case you will want the 4wd shroud.
How close is the distributor cap to the firewall? If it's real close, you need teh 4wd shroud. If it's a couple inches away than the 2wd shroud is what you want.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-06-2010, 12:01 AM   #11
70jnktrk
70jnktrk's Avatar
Re: Fan shrouds
Here is my sbc shroud..measures 5 3/4 inches at the top...hope this helps
70jnktrk is offline   Reply With Quote
Old 11-06-2010, 11:01 AM   #12
snj8198
snj8198's Avatar
Re: Fan shrouds
Thanks for your help guys,
I've got a big block and it's located in the rear most holes. The shroud i pulled out was 5 1/4" on top 5 3/4" on bottom and doesn't quite look like anything of the pics yet. This set up was put together by the previous owner many years ago when he did a big block conversion on the truck. When i purchase the truck i dropped my own bbc in but stuck with this accessory and fan shroud arrangement since it worked. I may have to go wander the salvage yard.
Could this shroud maybe from a 73-87 4x4?
70jnktrk your shroud could possibly work, but it makes me wonder why your is 5 3/4" on top and mine narrower on top than the bottom? If the motor leans a few degrees back that would effectively tip the top of the fan back making it sit further from the radiator than the bottom of the fan. Therefore the proper shroud should actually by wider at the top than the bottom? Just the opposite of what i have.
Just pondering over coffee. -steve
Steve
Old 11-06-2010, 11:06 AM   #13
NGN
NGN's Avatar
Re: Fan shrouds
burb71, a funny thing, I know of a 68 original with a stock straight 6 & auto and it has the whole shroud, not the metal topped shroud. It looks like the stock one used for a small block V8 but with a slight difference I'm guessing. I tried using a small V8 stock shroud thinking it's the same as the 68 straight 6 with my 67 straight 6, which I made into an automatic. It turns out there is a slight rub on the bottom right with the blade and shroud. So I was hoping to find one for a 6 cly or maybe there's something more that I need to figure out. I need to messure the 68 fan blades. Sssssoooooo, Sorry to carry on, snj8198 the # I got off a shroud from a 72 Suburban 2WD 350 V8 Auto with A/C is 3889079. I would think it be the same as a pick-up 2WD 350 V8 Auto with A/C. Your pic's do look different then 2WD, is your truck 4WD ? Or it's like 71swb4x4 mentioned. I have two shourds, not 4 sale, one off a 72 Suburban as said above with A/C and it measures 5 7/8 top center and the other one without A/C, 2WD 350 not sure if auto or manual that measures 5 1/8 top center, sorry no #'s on this one. Thanks for the info and time hope to of help. Nick
NGN is offline   Reply With Quote
Old 11-06-2010, 11:17 AM   #14
snj8198
snj8198's Avatar
Re: Fan shrouds
this is for the truck in my signature so it is a 4x4 with big block no a/c.
Steve
Old 11-06-2010, 12:39 PM   #15
71swb4x4
71swb4x4's Avatar
Re: Fan shrouds
None of the 67-72 GM's came with a big block and 4wd, so you may be searching for something that works, not something that was stock.
Old 11-06-2010, 05:31 PM   #16
snj8198
snj8198's Avatar
Re: Fan shrouds
ya ok. i figure i'll go dig around in the local pick-a-part.
Steve
Old 11-06-2010, 06:13 PM   #17
Shyguy
Junior Member
Shyguy's Avatar
Re: Fan shrouds
I have one out of a '74 in my 71 with a 454. It took a few adustments but it works out fine.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 11-06-2010, 09:16 PM   #18
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Fan shrouds
i am have a 4wd shroud on my 71 with a 350 (its a 2wd but the sb motor is in the 6cyl holes)
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 11-07-2010, 10:26 AM   #19
snj8198
snj8198's Avatar
Re: Fan shrouds
After looking at all these pictures im starting to believe the shroud i took out is not from our era but something else just cobbled in. Thanks for the pics guys. I will figure something out.
Steve
Old 10-07-2013, 06:26 AM   #20
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Re: Fan shrouds
Holy dead thread batman!
Seriously though. I'm replacing the fan shroud in my 72 c/10. I have the 350 in it, and my truck was originally a non-a/c truck, though I now have the bigger radiator in it (Texas!).
So... should I get the a/c fan shroud?
Seems like the non-a/c one I got doesn't fit too well at the top. There is a big gap between the should mounting holes, and the brackets it mounts to.
Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
