Old 11-09-2010, 10:42 PM   #1
vanceman
Key Parts Vs. Counterpart
I have been looking at some path panels and I have found Key parts from Top Banana and Counter Parts from TruckandCarShop to be similar on price on most things I need. My Question, is the Quality of these parts the same, as in the fit and material thickness? I bought some rockers from LMC about 5 years ago and the quality of the parts SUCKED and the material thickness was 22 gauge. I just don't want to get burned again. Thanks
vanceman is offline   Reply With Quote
Old 11-10-2010, 12:21 AM   #2
Rat Bastid
Rat Bastid's Avatar
Re: Key Parts Vs. Counterpart
im unhappy with counterparts as far as doors go,seems one door is from one vendor and the other didnt even begin to fit in the frame,matter of fact if i was you contact WES he a vendor here that im confidant in and knows much more about these companies than I,Personally he will get most my business from this point on.....but there are a lot of vendors on this site,but great question........good luck
Rat Bastid is offline   Reply With Quote
Old 11-10-2010, 12:27 AM   #3
trucks72
trucks72
trucks72's Avatar
Key Parts by far!!!!!
trucks72 is offline   Reply With Quote
Old 11-10-2010, 07:53 AM   #4
Counterpart sells Key Parts that they don't produce to fill out their line.Those boxes will be marked as Counterpart.I buy Counterpart products that key parts don't make to know what I get.
Old 11-10-2010, 07:04 PM   #5
vanceman
Don't really understand what you are saying here.
Old 11-10-2010, 08:26 AM   #6
Lee H
Lee H's Avatar
I'm disappointed in counterparts quality. Will try to stay away from if given the choice.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 11-10-2010, 09:55 AM   #7
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
So LMC Truck you guys in general think their quality is that bad?
Vanceman you said you bought from them like 5 years ago. Is it possible they have improved on their quality or is it the same old stuff?
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 11-10-2010, 07:02 PM   #8
vanceman
I bought rockers and they were 22 gauge material, The door handle I bought worked about 5 times then broke, and the floor pans were bent to hell( I guess so they would fit in the box) I will never buy from them again, you never get a second chance to make a first impression. I like Top Banana Parts because they tell you who makes the part while most don't. I don't want it to be crap shoot of whos part I get. I have heard good things about key parts, but had not heard much on counterparts so I appreciate all of youre comments. Keep them coming.
Old 11-10-2010, 10:02 AM   #9
barry h.
barry h.'s Avatar
I buy my sheet metal from kenny's truck in tulsa,ok good stuff
barry h. is offline   Reply With Quote
Old 11-11-2010, 10:20 PM   #10
Gene
Gene's Avatar
Just about everything I have bought from Kenny's is counterpart. All looks to be pretty good quallity.
Gene is offline   Reply With Quote
Old 11-10-2010, 10:50 AM   #11
Sinister
Between Trucks...
Sinister's Avatar
I have a Counterpart fender and I'm not so happy with the fit. I'd go with one of the Board vendors, they generally have nice stuff.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-10-2010, 11:24 AM   #12
stich626
I've had luck with goodmark , but that was 70 chevelle,
good luck
stich626 is offline   Reply With Quote
Old 11-10-2010, 12:22 PM   #13
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I just bought all my stuff from GMCPauls. COuldnt be any nicer product! Great customer service too!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 11-10-2010, 01:14 PM   #14
1956cameo
1956cameo's Avatar
I try to use as little aftermarket metal as possible. However if I cant find a donor patch I will buy aftermarket patch panels. I have bought quite a bit from CounterPart and the only complaint I have had up until now is the rocker box bolts (blazer only part) dont have good threads. I also bought a couple of blazer patch panels from GMC Pauls and had to do a little modifying to get them to work, but it was nothing that I thought was a big problem.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 11-10-2010, 01:34 PM   #15
dwcsr
Hollister Road Co.
dwcsr's Avatar
After market panels are all thinner than originals. As far as I can see its usually the closest MM under the gauge of the original panel. That doesn't add to much on a pillar panel or cab corner but its a lot on a rear fender or door or bed side. Doors are always a problem no matter who you buy from. Each production run can have its own issues and fit problems.
I know Key which sells Tri-plus is usually 18 gauge or thicker depending on the panel. Don't know about Counter Parts.
Old 11-10-2010, 07:33 PM   #16
I'm saying that both counterpart and Key Parts are parts producers,as in manufacturers of the parts.Counterpart makes a lot of parts,not just sheetmetal.Of the sheet metal they sell,there are items they don't produce themselves.Some of those parts are produced by Key Parts.Counterpart has their name put on these packages,a common business practice these days.
One myth I see here is that aftermarket sheet metal is a lighter gauge.I know for a fact that Key Parts are at least as heavy of a gauge.I believe others are as well,just don't know for a fact.
There are very few manufacturers of aftermarket sheet metal.None make the full line of parts.Vendors sell parts from a mix of manufacturers to offer a complete line.The cost of developing and producing most parts limits feasibility of more than one company to offer it.Only the most common parts are made by more than one maker.
I see a lot of vendors mentioned,not manufacturers.This includes Goodmark and LMC.LMC is big enough to have parts produces exclusively for them,but are not involved in manufacturing.
Old 11-10-2010, 08:51 PM   #17
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
There are 5 different manufacturers of sheetmetal for these trucks. Tri-Plus, Dynacorn, & Gordon are the only 3 of the 5 who's names I can remember and are the main 3 that you will see offered up here. I know that a company by the name of keystone buys what is known in the trade as "crash parts". What this means is a good bodyman can make them fit, but if you look closely you can see that the fit actually is not great and some body lines are missing. A bodyshop's customer is usually happy with this, but have no way of knowing what the weight or gauge of the steel is and because the vehicle was crashed, it looks great in comparison to what it did when it came in. By far Tri-Plus has the thickest steel, best fit, and finish. However Tri-Plus doesn't make everything so that is why (at least myself) we have to purchase parts from the other manufacturers. With our experience we have figured out who has the best parts and that is what we buy and supply.
Not all catalog companies are concerned about the best quality, and their prices will reflect that. It's whatever is cheaper. We discovered this by talking to different retailers about purchasing Classic Heartbeat's Exclusive parts. Our exclusive parts are high quality and not as cheap as the imported parts that are already out on the market. We were told by more than one catalog company that unless we could get more competitive with the price, they would continue to purchase from their existing suppliers. They deal with the problems that the lesser quality parts have by just replacing it with another and that usually satisfies the customer. Problem is the new part has the same problem and the customer just figures it doesn't get any better than that. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 11-10-2010, 09:25 PM   #18
vanceman
So who makes Key Parts?
Old 11-11-2010, 02:30 AM   #19
Musclerodz
key parts make the tri-plus line
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 11-12-2010, 07:20 PM   #20
dwcsr
Hollister Road Co.
dwcsr's Avatar
Tri-plus is a major supplier to Key Parts Inc, To the best of my knowledge Key does not make any parts. They are an importer only
Old 11-12-2010, 07:45 PM   #21
jb4short
Damn Yankee
jb4short's Avatar
Key Parts does in fact make parts that are not available from any other manufacturer.
jb4short is offline   Reply With Quote
Old 11-11-2010, 07:19 AM   #22
Sorry for the confusion.Key Parts = Tri-Plus.also,sorry for leaving out guys like Wes and others who are responsible for bringing parts to the market that none of the "biggies" bothered with.It's hard to lay it all out,but basically,some parts are only made by one source and some are made by a few.Many of the board vendors,and others that aren't mega companies,put together very helpful parts/components for our benefit.The best thing to do when buying sheet metal is to ask who makes a particular part,then come on here and ask for other's experience...or go with a vendor who has a reputation for only selling what they know is the best on the market.
Old 11-11-2010, 10:07 PM   #23
vanceman
Ordered my parts from Top Banana today, they are supposed to be Key parts. Thanks for everyones input.
Old 11-12-2010, 07:22 AM   #24
C20-67_N_MO
Does anyone have a source for Suburban parts?
Seems as the trucks have much more repo parts out there than these do.
Old 11-12-2010, 08:18 AM   #25
Check with Classic Heartbeat.
