Key Parts Vs. Counterpart
I have been looking at some path panels and I have found Key parts from Top Banana and Counter Parts from TruckandCarShop to be similar on price on most things I need. My Question, is the Quality of these parts the same, as in the fit and material thickness? I bought some rockers from LMC about 5 years ago and the quality of the parts SUCKED and the material thickness was 22 gauge. I just don't want to get burned again. Thanks
Re: Key Parts Vs. Counterpart
im unhappy with counterparts as far as doors go,seems one door is from one vendor and the other didnt even begin to fit in the frame,matter of fact if i was you contact WES he a vendor here that im confidant in and knows much more about these companies than I,Personally he will get most my business from this point on.....but there are a lot of vendors on this site,but great question........good luck
trucks72
Key Parts by far!!!!!
Counterpart sells Key Parts that they don't produce to fill out their line.Those boxes will be marked as Counterpart.I buy Counterpart products that key parts don't make to know what I get.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-10-2010 at 07:55 AM. |
I'm disappointed in counterparts quality. Will try to stay away from if given the choice.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Champagne Taste on Beer Budget
So LMC Truck you guys in general think their quality is that bad?
Vanceman you said you bought from them like 5 years ago. Is it possible they have improved on their quality or is it the same old stuff?
Coming Soon: Project 1970 Country Truck |
I buy my sheet metal from kenny's truck in tulsa,ok good stuff
Between Trucks...
I have a Counterpart fender and I'm not so happy with the fit. I'd go with one of the Board vendors, they generally have nice stuff.
Beat it to fit, Paint it to match... ![]() |
I've had luck with goodmark , but that was 70 chevelle,
good luck |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
I just bought all my stuff from GMCPauls. COuldnt be any nicer product! Great customer service too!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
I try to use as little aftermarket metal as possible. However if I cant find a donor patch I will buy aftermarket patch panels. I have bought quite a bit from CounterPart and the only complaint I have had up until now is the rocker box bolts (blazer only part) dont have good threads. I also bought a couple of blazer patch panels from GMC Pauls and had to do a little modifying to get them to work, but it was nothing that I thought was a big problem.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
Hollister Road Co.
After market panels are all thinner than originals. As far as I can see its usually the closest MM under the gauge of the original panel. That doesn't add to much on a pillar panel or cab corner but its a lot on a rear fender or door or bed side. Doors are always a problem no matter who you buy from. Each production run can have its own issues and fit problems.
I know Key which sells Tri-plus is usually 18 gauge or thicker depending on the panel. Don't know about Counter Parts. |
I bought rockers and they were 22 gauge material, The door handle I bought worked about 5 times then broke, and the floor pans were bent to hell( I guess so they would fit in the box) I will never buy from them again, you never get a second chance to make a first impression. I like Top Banana Parts because they tell you who makes the part while most don't. I don't want it to be crap shoot of whos part I get. I have heard good things about key parts, but had not heard much on counterparts so I appreciate all of youre comments. Keep them coming.
#15 |
I'm saying that both counterpart and Key Parts are parts producers,as in manufacturers of the parts.Counterpart makes a lot of parts,not just sheetmetal.Of the sheet metal they sell,there are items they don't produce themselves.Some of those parts are produced by Key Parts.Counterpart has their name put on these packages,a common business practice these days.
One myth I see here is that aftermarket sheet metal is a lighter gauge.I know for a fact that Key Parts are at least as heavy of a gauge.I believe others are as well,just don't know for a fact. There are very few manufacturers of aftermarket sheet metal.None make the full line of parts.Vendors sell parts from a mix of manufacturers to offer a complete line.The cost of developing and producing most parts limits feasibility of more than one company to offer it.Only the most common parts are made by more than one maker. I see a lot of vendors mentioned,not manufacturers.This includes Goodmark and LMC.LMC is big enough to have parts produces exclusively for them,but are not involved in manufacturing.
#16 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
There are 5 different manufacturers of sheetmetal for these trucks. Tri-Plus, Dynacorn, & Gordon are the only 3 of the 5 who's names I can remember and are the main 3 that you will see offered up here. I know that a company by the name of keystone buys what is known in the trade as "crash parts". What this means is a good bodyman can make them fit, but if you look closely you can see that the fit actually is not great and some body lines are missing. A bodyshop's customer is usually happy with this, but have no way of knowing what the weight or gauge of the steel is and because the vehicle was crashed, it looks great in comparison to what it did when it came in. By far Tri-Plus has the thickest steel, best fit, and finish. However Tri-Plus doesn't make everything so that is why (at least myself) we have to purchase parts from the other manufacturers. With our experience we have figured out who has the best parts and that is what we buy and supply.
Not all catalog companies are concerned about the best quality, and their prices will reflect that. It's whatever is cheaper. We discovered this by talking to different retailers about purchasing Classic Heartbeat's Exclusive parts. Our exclusive parts are high quality and not as cheap as the imported parts that are already out on the market. We were told by more than one catalog company that unless we could get more competitive with the price, they would continue to purchase from their existing suppliers. They deal with the problems that the lesser quality parts have by just replacing it with another and that usually satisfies the customer. Problem is the new part has the same problem and the customer just figures it doesn't get any better than that. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#17 | |
#18 |
Mike Redpath |
#19 |
Sorry for the confusion.Key Parts = Tri-Plus.also,sorry for leaving out guys like Wes and others who are responsible for bringing parts to the market that none of the "biggies" bothered with.It's hard to lay it all out,but basically,some parts are only made by one source and some are made by a few.Many of the board vendors,and others that aren't mega companies,put together very helpful parts/components for our benefit.The best thing to do when buying sheet metal is to ask who makes a particular part,then come on here and ask for other's experience...or go with a vendor who has a reputation for only selling what they know is the best on the market.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-12-2010 at 08:16 AM. |
#20 |
Ordered my parts from Top Banana today, they are supposed to be Key parts. Thanks for everyones input.
#21 |
#22 |
Does anyone have a source for Suburban parts?
Seems as the trucks have much more repo parts out there than these do.
#23 |
Check with Classic Heartbeat.
#24 |
Thanks for the idea.
They have a good selection of sheetmetal for the 'burbs.
Coming Soon: Project 1970 Country Truck Last edited by C20-67_N_MO; 11-12-2010 at 09:01 PM. |
#25 |
Hollister Road Co.
