Old 12-12-2010, 03:17 AM   #1
shpuz
converting 2x4 to 4x4?
havnt really posted much, but i just bought a 1974 chevy, and have been thinking of making it 4 wheel drive. is this hard to do? not really worried about cost, just mainly curious about what all ill need besides the obvious front axle, trans and tranfercase, suspention and matching gears. just wasnt really sure what els would need to be replaced/ modified. any tips?
shpuz is offline   Reply With Quote
Old 12-12-2010, 10:01 AM   #2
Mattman2010
Mattman2010's Avatar
Re: converting 2x4 to 4x4?
If I where you I would try to find a 4x4 frame, or an old beat up body 4x4 truck and swap your body over. I am converting a crew cab to 4x4 only because the 4x4 frames are hard to find. Having a parts frame is going to be the easiest way as you will want all suspension brackets mounted to the frame. The spring hangers for the rear are different between a 2x4 and 4x4 and if you use the 2x4 spring hangers for the rear the truck will not be level with the front. You could possible do a lift or something on the back to compensate for that.
Besides the obvious the only thing you will really need to modify is probably the cab floor. I am pretty sure in 74 the tranny hump was bolted in so all you would need to do is unbolt the current tranny hump and bolt in the correct 4x4 hump.
Matt
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 12-12-2010, 10:46 AM   #3
LONGHAIR
Once again.....Conversions are for vehicles that were never made that way in the first place. Start with an actual 4x4.
This is a case of trying to re-invent the wheel.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-12-2010, 10:55 AM   #4
Da88burban
GM's 4 Life
Da88burban's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=168231
Heres a good thread on converting both ways.
Jack
'54 Chevy 3100 "Just a Mess"
'74 Chevy Super 10 468BB "One Fast Rust Bucket"
'86 Pontiac Fiero GT
'88 Chevy burb "Tha Big Turd"
'93 GMC Safari "Bone Crusher"
.................____________
.............../______l___|___\____
;,;,;,;,;,;,;|__(O)_| __l___l__(O) |
Da88burban is offline   Reply With Quote
