Chance
![]() Join Date: Sep 2001
TH400 to Transfer Case Adapter
Does anyone know where I can find a TH400 to NP205 transfer case adpater. I have a TH400 that I want to install in my 1972 Cheyenne 3/4 ton 4x4 but I need an adapter for the TH400 to bolt to the transfer case. If anyone knows please let me know where I can find one. Thanks!!!
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
Re: TH400 to Transfer Case Adapter
there r 2 different th400 205 case a figure 8 like our trucks and a round 6 in 85 and newer trucks ,,, if u have a th350 now and just wast to install a th400 u will have to take your case out and have it modified.. the 400 case uses a biger input bearing and this is what you have to have machined in the case to change over to a 400 case ,,, ive seen the input shafts for 140 and the adapters for 200 ,, (a little pricey if you ask me) I would try to find a case allready set up 4 a 400 ,, I think it would be a little cheaper but thats just my 2 cents,,, pm me if u need help finding parts or more info ,,,, KING
67 chevy short step 2wd 427 71 chevy short fleet 4x4 396 72 gmc jimmy 2wd 377 71 chevy blazer 4x4 454 69 chevy longhorn 5.9l cummins 72 chevy 400 2wd custom camper 67 chevy lwb 4x4 454-in pieces 67 chevy panel soon 4x4-400 67 gmc dump 4x4 1 ton-305 WTF!! 72 chevy 3/4 ton 4x4 burb 350 70 chevy panel 2wd 302 5 speed tko "THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!! |
check with member 1TonMudder on here..he has a bunch of 4x4 parts.
You can buy New adapter for $220 most used one are more than that .
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
Chance
"Junkyard Dog"
![]() Join Date: Jan 2008
Yes, it is correct as long as you have 84 and older t-case. Their description says 71-85 which is incorrect. 85 and later, as all ready mentioned is the 6 hole round pattern. Just for gp the NP205 was not used behind the TH400 till 1980.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
