needin' money
speedometer problem
okay, i recently purchased a 2000 suburban for my parents, all of the gauges except for the speedo work, and the trans doesn't shift into 2nd till after 4k rpm's and won't go into 3rd or 4th, i'm thinking these issue's are related, cause if the computer doesn't know how fast you are going, it won't know when to shift. Does anyone have a fix for this problem? i have already replaced the VSS
SWB Stands for Short Wide Bed |
![]() Join Date: Sep 2005
Re: speedometer problem
the gage will not cause that. you can buy reman clusters from advance auto parts for about 300 dollars. or by the rebuild service on ebayfor like 100 that you send them your cluster and they rebuild it and send it back to you. but i've had several come though my shop this week that the speedo is broke and it makes no differance on how it drives. you can take the whole thing out and drive and it wont brother it.
the gages missing upo area known gm issuse
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 01-20-2011 at 06:17 PM. |
69' Chevy Stepside
![]() Join Date: Mar 2008
The shifting problem with the transmission sounds like the PCM isn't getting a signal from the VSS. I would scan for codes and see what comes up, I would think it would throw a code with the transmission shifting like that!
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
needin' money
purple w/white stripe wire was ripped in 2, saudered it together and now have speedometer, and also have 3rd and 4th, and trans shifts right, i knew they had to be related
87 Wanna Be K30
My 99 is doing the same thing and I replaced the vss and it didn't work. What wire, where is it, what does it control?
Was: 1987 V10 Silverado TBI 350/700R4/208 with 3.42 gears Is: A wanna be K30 330hp 350/465/205/D60/14FF with 3.73 hydroboost, 4 Core radiator, electric fans, Centerforce Duel Friction, Locker, 6inch Soft ride lift, etc.... |
Look at the wiring at the VSS sensor, A broke or shorted wire is generally near the plug.
