Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-14-2011, 04:40 AM   #1
low&slow
How fast do YOU think she will go ?
I have a '69 c10 lwb pick-up. It's completely gutted out. The truck is 90% stock. Stock suspension. Stock posi track rear end. Stock gears. The only thing not stock in it is the one racing seat and the 500 CI Caddy backed by a T400. The Caddy is all stock other than an aluminum intake, aluminum water pump, and a 750 Holley. Before I go out and decide to buy some horse power add on's and get banded for running to fast without proper safety, How fast do you think she will go?
low&slow is offline   Reply With Quote
Old 03-14-2011, 06:24 AM   #2
81ShrtBox
MadMan
81ShrtBox's Avatar
Re: How fast do YOU think she will go ?
Be sure to get some video.... Those Cadillac motors will scoot pretty good.
81" Shortbed C10 Full Restoration underway, who needs a budget?? LS Pro Touring Build
81ShrtBox is offline   Reply With Quote
Old 03-14-2011, 10:13 AM   #3
pockets
pockets's Avatar
with a stock caddy, I would say high 14's - low 15's. They have torque, but no horsepower
Project Bad Karma
pockets is offline   Reply With Quote
Old 03-14-2011, 07:07 PM   #4
djracer
djracer's Avatar
I say mid to high 13's.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-14-2011, 10:05 PM   #5
BIG KRIS
BIG KRIS's Avatar
Ditto.
Flowershop Hip Hop & Street Rods
Dropmember
83 Custom Deluxe Almond on Almond
85 Silverado White on Red/Now Chevy LeMans Blue
Rendering in Truckin magazine vol 36 no. 11,2010
BIG KRIS is offline   Reply With Quote
Old 03-14-2011, 10:11 PM   #6
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Mid 15s
-Automatics win races, 6-speeds impress high school kids
-Save a tree, support your local dragstrip.
-"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui
columbuscarsandcoffee.net and on Facebook
ProStreet68SB is offline   Reply With Quote
Old 03-14-2011, 10:58 PM   #7
Pont406
Mid 13s on slicks. Maybe 15s on regular tires.
Pont406 is offline   Reply With Quote
Old 03-15-2011, 12:44 AM   #8
cableguy0
What rear gears do you have? What size are the tires? More than likely you are going to liquidate the tires so your 60' time will be horrible.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-15-2011, 05:29 AM   #9
81ShrtBox
MadMan
81ShrtBox's Avatar
Comp Cam, springs and an intake it will pick up a few ponies.
Old 03-15-2011, 06:27 PM   #10
low&slow
So you guys are saying mid 13's. If I put some slicks on it and a 250 shot nos, would that put me in the high 12's?
Old 03-17-2011, 12:43 AM   #11
81ShrtBox
MadMan
81ShrtBox's Avatar
shouldnt take a 250 shot to run that
Old 03-17-2011, 02:40 PM   #12
stich626
first off, mid 14's
the caddy 500 is all done at 4200 stock.. and those 40 y/o valve springs are not gonna help your cause..
and nos, on cast pistons.. yes it can be done, but.. I wouldn't ,inless you got the tune spot on..
I'd go with some advance spings and holley jets, and pump camps..
good luck..
stich626 is offline   Reply With Quote
Old 03-17-2011, 03:19 PM   #13
pockets
pockets's Avatar
If a stock long block caddy puts that truck into the 13's, my engine should run 11's; and I'm pretty certain it won't.
Have to remember, stock 500's only made 200 horse in the mid 70's engines, 365 or so in the 71 and the 70 was like 400. Yes they made lots of torque (500ftlbs in the 70/71). So if you have a 70 or 71 then it could conceivably run low-mid 13's. If you don't, you'll be lucky to break into the 14's.
Having said that, it is fairly easy to build a 400-450hp caddy with the stock heads and using a decent cam, even using cast pistons at 8:1 compression. 500hp isn't too far off either (see these specs)
BTW, if you decide to get rid of it, let me know, I'll take it
Project Bad Karma
Old 03-17-2011, 11:57 PM   #14
low&slow
It's a stock 1969 500 caddy. My grandpa once told me that they make like you said 400 horses, but he also said by just putting an aluminum intake on it, that alone will add 20 horses. True, or not true?
Old 03-18-2011, 10:43 AM   #15
pockets
pockets's Avatar
I don't know for sure, but it's possible. The 365 and 400 horse motors had 10:1 compression, the lower horse motors had like 8.5:1. Just something to keep in mind.
Sounds like you got a good base to start with. I would sure love to have a caddy motor myself
Project Bad Karma
Old 03-19-2011, 06:33 AM   #16
low&slow
Thanks for the input guys. I have not yet got it out to the track. Racing season don't start for another few months. Right now I'm at about $250 including shipping and handling to get it to the track with all the parts I need for it.
I will take some pictures as I start back up on the build this Monday. Thank goodness dad goes back to work. Time to work on the ol' girl again
I will also take a few videos of maybe a burn out or something, but defiantly take a video when she goes to the track.
Thanks again guys,
Wyatt
Old 03-19-2011, 05:46 PM   #17
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
gramp was spot on and not only that but you loose about 30lbs off the top of the block DO NOT TURN IT MORE THAN 4800 RPM my truck runs 100 flat in the 1/4 all day with stock tune no idea on the time though it was a radar run..I'm dieing on the 60 foot time since the Mickey T's are on fire for at least that far...
my set up is:
70 longbed fleet
1969 500 caddy (stock)
th 400
3:73's
31x15 or 18 Mickey Thompsons
it pulls like a monster and will pin you to the seat...just don't plan on any highway use above 70 mph (3000 rpm) I'm planning on going back to the 3.08's for drivability.....Also keep your shots down to 100 and if you can pop for the delay or your going to baste the tires more!!
check my build for more info and a link to all the info you could ever want
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-21-2011, 04:42 PM   #18
low&slow
my set up is:
70 longbed fleet
th 400
3:73's
Jeff
Thanks Jeff. I'm thinking from what you put, my should run a tad slower since I don't have Mickey Thompsons. Also wondering since yours goes that fast, would mine go ruffly that fast as well on stock suspension?
Old 03-20-2011, 03:36 PM   #19
81ShrtBox
MadMan
81ShrtBox's Avatar
http://www.crankshaftcoalition.com/w...gine_knowledge
try this link.. takes the guess work out
Old 03-21-2011, 04:44 PM   #20
low&slow
Thanks for the site. I've been trying to find a site for a long a** time just like that. That helps tremendously.
Old 03-21-2011, 12:23 PM   #21
Wasted Income
Boosted Member
Wasted Income's Avatar
My guess is low 14s.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-21-2011, 04:53 PM   #22
Hottrucks
Hottrucks's Avatar
define fast??? if you can get it to stick it will be fast for a street truck if you want to race at the track bring your check book!! for starters your going to need a valve train its the weak point of these engines no use spend big $$ until you do that
Old 03-21-2011, 04:56 PM   #23
low&slow
Fast as in I want to get it in the low 10's. No fast than that though. It's being built strictly for racing. It will never see a road.
Old 03-21-2011, 11:58 PM   #24
Captainfab
60-66 Nut
You're talking some considerable money to go that fast in one of these trucks.
Old 03-21-2011, 08:55 PM   #25
djracer
djracer's Avatar
get rid of everything that is not absolutely needed. Lighter is faster.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
