Old 04-03-2011, 03:16 AM   #1
Mrtn15
Mrtn15's Avatar
How to install torque convertor?
Okay well.. I have my transmission all bolted up' and my torque convertor doesn't quite make it close enough to my flywheel?
And was I supposed to fill up the torque convertor with fluid before install onto transmission? Because I didn't!
Note: this is a th 350 trans with shift kit!
1986 Single cab 2WD Chevy 350/350
1977 Single cab Dually C30 BB454!
Mrtn15 is offline   Reply With Quote
Old 04-03-2011, 04:16 AM   #2
Pop's C-10
Pop's C-10's Avatar
Re: How to install torque convertor?
you can slide it foward tha lil bit to get it to mate up to tha flywheel.
Pop's C-10 is offline   Reply With Quote
Old 04-03-2011, 06:58 AM   #3
one low c10
I always fill up the converter with fluid, I have heaard it is bad for the pump not to. I dont know if that is true or not but it does save time checking and filling the fluid when you start it back up! the converter holds quite a bit of fluid. when I put converters in I spin them and push on them at the same time. you should feel it "click" a couple times. then when you bolt the engine back in you can slide it forward a lil bit to bolt up the converter.
one low c10 is offline   Reply With Quote
Old 04-03-2011, 08:32 AM   #4
MWood
MWood's Avatar
You are supposed to measure the torque convertor to bellhousing clearance and TC to flexplate clearance too I believe. The instructions that came with my TC for the S-10 had measurements. If it doesn't mate using the measurement, then you are supposed to use spacers I think. Not too sure though. Just give a trans shop a call and ask, but I would not just slide the TC forward without making sure the measurements are right.
'00 S-10 ZR-2 - 383 ci, 880 block, forged internals, AFR 190cc heads, 36 lbs injectors, 33's, built 4l60e
'86 C-10 2wd P/U
'03 Dodge 3500, DRW, 5.9, Auto, FASS 150/150
MWood is offline   Reply With Quote
Old 04-03-2011, 08:40 AM   #5
MWood
MWood's Avatar
http://www.hotrodders.com/forum/torq...gap-59937.html
'86 C-10 2wd P/U
Old 04-03-2011, 08:51 AM   #6
MWood
MWood's Avatar
http://www.partshp.com/ConverterInstructions.htm
http://www.tciauto.com/Products/TechInfo/FAQ.asp#4
http://www.ls1tech.com/forums/automa...installed.html
'86 C-10 2wd P/U
Old 04-10-2011, 08:31 AM   #7
MWood
MWood's Avatar
Any luck?
'86 C-10 2wd P/U
Old 04-10-2011, 09:59 AM   #8
Mrtn15
Mrtn15's Avatar
I got the convertor! And everything else right! Thanks for your help guys! It works like a charm
help wanted, th350 installion, torque convertor, transmission
