06-15-2011, 04:21 PM | #1 |
Member
Help with Amp
Ok, I've put a new radio in the truck, have 6" round speakers in kick panels and put 6x9's under the seat. It's sounds good, but just not as loud as i think it should be, easpecially going down the highway...,
I have an old school Hi-Fonics Odin 150 watt Amp, What is the best way to hook it up? To just the 6x9's or to all 4 speakers? If to all 4 how should i wire it? Any help would be much appreciated, been a long time since i've done much Audio work...
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
06-15-2011, 04:32 PM | #2 |
Charlie Daniels w/ a Tq Wrench
Re: Help with Amp
Being that it's a two channel, and "150 watts" which probably translates into 60-75 watts RMS, it would be underpowered going to all 4 speakers. I would probably just run the 6x9s off of it, and if the amp has a built in crossover send only lows to the 6x9s. Then I would run the 6.5"s off the head unit, up the highs and cut the bass on the headunit to send only highs to the front 6.5s.
This is how I have my 78 setup, except with two 3.5s in the dash rather than 6.5s in the kicks. I am quite happy with the setup, and it is much better than when I had all four running off the headunit, especially since I knew I was really lacking in bass since I had to keep the bass turned down low for the 3.5s. Now sending the lows to the 6x9s and the highs to the 3.5s it sounds much more balanced. Beautiful interior BTW.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s Last edited by GCncsuHD; 06-15-2011 at 04:33 PM. |
06-15-2011, 06:41 PM | #3 |
Re: Help with Amp
2 x 120W @ 2 ohms (12V) from what I can find. Depending on the power rating of the speakers, you could run all 4 with good performance. If the 6x9's need more than 75w rms each, then just run the 6x9.
I wouldn't filter the highs too much on the 6x9s since they are 3ways.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
06-15-2011, 08:49 PM | #4 | |
Member
Re: Help with Amp
And GCncsuHD, thanks for the comments, and my truck has also been in the family a while, was originally my grandfathers
06-15-2011, 10:21 PM | #5 | ||
Re: Help with Amp
And I would filter the highs out of the 6x9s to get the best highs from the 6.5s without interference from the 3way 6x9s screwing with the sound since they are not aimed properly for highs and due to the speed of sound the sound will reach your ears at different times, it is very slight, but it is noticeable. The wavelength of the lows travels differently and aiming for that is not nearly as important. Quote:
Good to see these trucks staying in the family, my 67 was bought new by my great grandfather as well
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
06-16-2011, 09:39 AM | #6 |
Member
Re: Help with Amp
Ok, you guys know a heck of a lot more than me about this, i appreciate all the help. Think i'll just hook it up to the 6x9's and see how that works, it's an easier install anyway and they do need the most help since the bench seat and bad angle they're sitting at is killing them. Thanks again and will let you guys know how it works out.
06-16-2011, 11:40 AM | #7 | |
Re: Help with Amp
06-17-2011, 11:42 AM | #8 |
Member
Re: Help with Amp
Hopefully this is the last question. The AMP has a place for a wire on the back for what it calls (remote turn on) How would i hook this up? Do i need to run a 12v wire with a switch in it or what? thanks!
06-17-2011, 12:03 PM | #9 |
Re: Help with Amp
That is the wire that is used by the deck to turn the amp on. If you aren't using a deck with a wire for power antenna, then you can run a 12v switch. That's what I am running since I am using my MP3 player to push my tunes.
06-17-2011, 12:08 PM | #10 |
Re: Help with Amp
Using the "power antenna" wire is not a good idea, most decks shut power off to that wire if you go to AUX or CD mode, which in turn would cut power to the amp as well, it should have a dedicated remote turn on wire.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s Last edited by GCncsuHD; 06-17-2011 at 12:08 PM. |
06-17-2011, 01:42 PM | #11 |
Member
Re: Help with Amp
Here's the wiring diagram from my radio. Do i have an option other than the yellow auto antena?
And i'm assuming that i'd use the Line out RCA's to go to AMP, then hook speakers directly to the AMP? And am i correct that the AMP has to always be on if the radio is on? Would be nice to be able to listen to the radio without the power drain from the AMP if the truck wasn't running...
06-17-2011, 02:02 PM | #12 |
Member
Re: Help with Amp
So if i wanted to try and run all 4 speakers, is this how i should wire it? Excuss my hand drawing, i know it's not that good. Also, still not sure the best place to hook up the Remote Turn On.
06-17-2011, 01:36 PM | #13 |
needs more $$$
Re: Help with Amp
Don't be scared of wiring the speakers from the amp in parallel, it's the simple one. It just running 1 channel to 2 speakers. If it were me doing this, I'd run 1 channel to both 6x9's and the other channel to the 6's in the kicks. By doing this, you'll lose your ability to do left or right balance, but at the same time you can use the left or right balance to adjust the levels of front to rear incase one set doesn't like to be as loud as the other.
To do this, simply run 2 sets of speaker wires off channel 1 to both the 6's, then do the same with channel 2 for the 6x9's. This will get you the most power out of your amp, but as for it being 2 ohms, that really depends on the ohm rating of your speakers.
1970 2wd Blazer |
06-17-2011, 02:26 PM | #14 |
needs more $$$
Re: Help with Amp
It's hard to say with 100% accuracy if that remote wire on the radio is the right one. But, if you put a test light to it and it's off when the key is off and on with key on, it's the right one. All you need is a key activated wire, so if it's not, just tap into any wire that is ACC powered and use it.
Also, you're speakers are already wired as I desicribed (parallel). You can easily just take the wires off your radio and plug them into the amp just as they are and you're set for the speaker wire wiring.
1970 2wd Blazer |
06-23-2011, 02:38 AM | #15 |
Re: Help with Amp
Just my 2 cents but you can do as everyone has said to discover if the yellow wire will work for you as a remote wire and if you still want to have the ability to listen to your radio you can wire in a switch in line, running off of said yellow wire. That way you can choose whether or not to listen to your radio with the amp on or off and do not have to worry about draining the batt due to the fact the power will be cut once you remove the keys. I've set up alot of stereos that way so my buddies can turn off the big subs when they have kiddos in the car, and have never had any issues.
06-23-2011, 10:46 AM | #16 | |
Member
Re: Help with Amp
06-27-2011, 02:45 AM | #17 |
Re: Help with Amp
Sorry it took so long to respond. But if you want the ability to control whether or not the amp is on, You will have to hook it up with the two 6" speaker's directly to the deck and then run the two 6x9's to the amp. This way when you want to really hear your music in your truck you can kick on the amp and power up the two 6X9's and when you just want to sit and listen and not worry about draining your batt you can kill the amp and just listen to the front two 6's. It's not a perfect solution but it does give you another option. It'll look something like this.
06-28-2011, 10:37 AM | #18 | |
Member
Re: Help with Amp
06-28-2011, 05:18 PM | #19 |
Re: Help with Amp
Are the 6x9's in boxes? if they are not they will sound horrible. I can't tell from the pictures. I would not run any of the speakers off the radio and I would put both left speakers on one channel and both right channel speakers on the other. Any speakers hooked to the amp will not play when the remote wire is not on.
There is some bad info in this thread. If anyone needs help on anything stereo related pm me. I have done it all and been doing it for a living since 1986.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
06-30-2011, 12:28 AM | #20 |
Re: Help with Amp
if it was me, I'd find another small amp and use two one for the fronts and one for the 6by9's or get a 4 channel amp..
that hiphonic amp driving 4 speakers will set the failsafes in the amp as it overheats no matter the ohm load.. it's not a high current amp design.. I've never had good luck with that brand.. they always cut off ,overheat if you drive your truck any lenth of time, with the volume up.. you'll not be happy with that amp.. |
06-30-2011, 05:53 AM | #21 |
Re: Help with Amp
That is a very old very decent amp and it should not have a problem running 2 ohm stereo. Run atleast 8 ga wire to it and ground it with 8 ga straight to the floor with the paint scraped away. Make the ground 18 inches or less. You already have it just try it. If you are no happy with the results then change it. I think you will be more than pleased with it.
06-30-2011, 10:46 AM | #22 | ||
Member
Re: Help with Amp
[quote=djracer;4760958]Are the 6x9's in boxes? if they are not they will sound horrible. I can't tell from the pictures. I would not run any of the speakers off the radio and I would put both left speakers on one channel and both right channel speakers on the other. Any speakers hooked to the amp will not play when the remote wire is not on.
Yes, the 6x9 are in boxes, not real big ones, but as big as under seat would allow. The reason i was thinking of running the 6.5's off the radio was so that if the truck wasn't running i could still listen to the radio without having to worry about killing my battery. Is this a bad idea? Quote:
06-30-2011, 11:20 AM | #23 | |
Re: Help with Amp
it will clip like mad and either shut down or burn up tweeters and or mid range speakers |
06-30-2011, 04:35 PM | #24 |
Re: Help with Amp
If the amp did anything out of the norm it would be get hot and shut off. Its only gonna clip if you over drive it. If you listen to this or any other amp and back off when it sounds bad you won't hurt anything at all. I have run speakers rated at 35 watts a channel with 125 watts a channel and not had a problem. This amp is much higher quality than you think. Its just old. The old Hyphonics stuff was very high quality.
Custom 1970 I would hook all the speakers to the amp. If you listen at lower volumes the amp is not gonna be that bad on your battery. Higher volumes it will draw more current.
07-01-2011, 08:56 AM | #25 | |
Re: Help with Amp
I'm out. feel free to help in blow up the speakers |
