Re: Help with Amp
That is a very old very decent amp and it should not have a problem running 2 ohm stereo. Run atleast 8 ga wire to it and ground it with 8 ga straight to the floor with the paint scraped away. Make the ground 18 inches or less. You already have it just try it. If you are no happy with the results then change it. I think you will be more than pleased with it.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#2 | ||
Member
Re: Help with Amp
[quote=djracer;4760958]Are the 6x9's in boxes? if they are not they will sound horrible. I can't tell from the pictures. I would not run any of the speakers off the radio and I would put both left speakers on one channel and both right channel speakers on the other. Any speakers hooked to the amp will not play when the remote wire is not on.
Yes, the 6x9 are in boxes, not real big ones, but as big as under seat would allow. The reason i was thinking of running the 6.5's off the radio was so that if the truck wasn't running i could still listen to the radio without having to worry about killing my battery. Is this a bad idea? Quote:
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
#3 | |
Re: Help with Amp
it will clip like mad and either shut down or burn up tweeters and or mid range speakers |
