Speedometer makes clicking noise.?
Sometimes my speedometer makes an annoying clicking noise at my dash, anyone know what would cause this or is it normal?
Posted via Mobile Device |
Cruzin
Re: Speedometer makes clicking noise.?
Cable could need some lube, i pulled mine completely out from the inside and lubed it up problem solved.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
~Rest In Peace~
can you make a voice record or can you mimic the click ?
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
Anyone know if the 2wd trucks all have the same length cable? I'm just going to replace the cable.
Thanks Posted via Mobile Device |
What can you lube it with?
![]() Join Date: Jan 2010
i used a graphite spray. worked well.
mines doing the same thing with brand new cable and old original speedo and housing
disconnect the cable from the tranny, chuck the end in a drill and see it still makes noise
same problem here. subscribed for solutions.
Your speedo head has started to go bad. It will continue to get worse until the needle starts bouncing all over the place and then won't move at all. Replace your speedo head.
I have experienced a loud ticking noise when I had an exhaust manifold leak, sounds exactly like a ticking speedometer from the drivers seat... can you hear it under the hood?
1967 GMC 3/4 ton Fleetside 350 ci Chevy I'd rather do it myself and spend the extra 500 dollars Last edited by sleepingbag; 10-10-2011 at 08:33 PM. Reason: sleepy. |
#15 | |
Thanks all. Posted via Mobile Device |
#16 |
![]() Join Date: Feb 2011
Here let me try....(clearing troat)..Hmnnn..Hmnnn...Hmnnh...
Clik, clik, clik,clik.clik,clik,tat,tat,tat,tat,tic,tic,tic,..(improve bouncing needle)..clik,clik Boing..clic,tac, tic, Boing......I used to do voice over work. Tha tha that's all folks....a little levity ok?
MusicMan70 1961 GMC Suburban |
#17 |
I believe the speedo head and gauge (face and needle) are a single unit. Is the LMC unit a remanufactured OEM speedo head, or is it a Chinese repop? Either way, LMC should replace the unit for you in my opinion.
#18 |
I'm sorry , I bought this from classic parts USA. Waiting to hear back from them. Anyone ever delt with them on a return?
