Rear custom four link pics!
I wanna see what some of yall have done/seen. Lets see em!
Re: Rear custom four link pics!
Don't know how custom it is but this is one i put under the '51 suburban. It's from TCI
vintage car junkie
Heres a picture of the rear setup on my 50.
1950 chevy truck, s10 swap, bagged, v8, 18s My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761 |
I would like to see a close up of the front arm bracket and length of the arm, Thanks
#5 | ||
vintage car junkie
thanks That is a work of art
Is that a watt's linkage in the rear? it looks like there is something between the shocks
I just pulled the TCI four liunk out of my 57 and fab up new front mounts.I think that the front mount hang way to low. will try to get some pic
Those are sick guys!
Not the best pics but here are a few of mine.
Kim |
great work guys - kim your truck rocks!
Here's what my unfinished parallel 4 link/ watt's link looks like.
#15 |
i like the watts linkage. looks nice.
#16 |
nice welding.
#17 |
#18 |
Here is what we have concocted, tell me what you think, if yall see strength's or weakness's in doing it this way.
'51 Chevy 3100 longbed pickup - bagged/MII/4link/bravada 3:73 posi rear. |
#19 |
![]() Join Date: Jun 2006
HRRookie why exactly are you mounting the 4-link outside the frame rails? Are you not planning to mount a wide set of tires out back? Only you and Kim57 have real 4-links of the street variety.
#20 |
You got it. I considered running a huge tire but I won't be making enough power to justify it. On top of that, I didn;t have to take out the crossmember where thr front brackets mount.
#21 |
again let me say you guys do great work !
#22 |
Studio Jak,
I see a problem with the panhard rod being on top of the axle. The panhard rod needs to be in the middle of the arc that the axle panhard rod mount will scribe in motion. In other words, at the top of the arc, the panhard rod will be centered, at the bottom of th arc it will pull the axle to the right. If the panhard rod was mounted on the axle centerline, it would have maybe 6-7 inches of up and down movement without appreciably pulling the axle to one side. |
#23 | |
#24 |
here is a few pictures of my 4 bar setup.with the new c-notch had to make new front mount because the old mount were to low.and now with the rearend in have to make up new mounts for the coil overs and the panhard bar.
#25 |
Here's what i came up with.
