10-06-2011, 08:57 AM | #1 |
Glove box door mounting
Anyone have some pictures of glove box door mounting for 64-66,mine did not have one and recently got one from a member here and need to see what mounting hardware it uses to mount it. Any help would be appretiated.
10-06-2011, 09:11 AM | #2 |
Re: Glove box door mounting
hinge along bottom and two brackets that slide into slots in dash then screw onto door
10-06-2011, 09:27 AM | #3 |
10-06-2011, 09:34 AM | #4 |
i used allen head bolts that i painted black, forget the bolt size tho... around 1/8 i think. same size bolt as the door pannels i believe.
10-06-2011, 12:09 PM | #5 |
I think they are smaller. I converted my door panels to use allens but the glove box uses some smaller ones.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
10-06-2011, 01:18 PM | #6 |
I think im going to try this j nut and screw setup, i have a bin of some new ones. To mount the hinge to the dash on the sides of the box door.
10-06-2011, 04:36 PM | #7 |
takes 1/4-20 by 3/8 hex heads. should be weld nuts behind dash holes, retap them first!!!!!!
10-06-2011, 04:37 PM | #8 |
the screws that hold the brakets to the door have a flange built into them.
10-28-2011, 07:58 AM | #9 |
you're welcome
