Old 11-12-2011, 12:17 PM   #1
Harley1650
1963 C-10 BBC/Muncie 4 spd
Harley1650's Avatar
key switch tumbler loose
The key tumbler in my ignition switch works fine, but the problem is I can just pull it out with the key! Kinda like an anti theft device I guess lol....What holds the tumbler into the housing for the ignition switch? Thanks
Harley1650 is offline   Reply With Quote
Old 11-13-2011, 08:13 AM   #2
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: key switch tumbler loose
There should be a pin hole next to the key hole.
with the key in and positioned at the acc position,stick a paperclip (or a chunk of mig wire)into the hole to unlatch the barrel.
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 11-13-2011, 09:28 AM   #3
Harley1650
Harley1650's Avatar
I saw the "paper clip trick" when I searched, does that secure the tumbler too?
Old 11-13-2011, 11:45 AM   #4
rbar
rbar's Avatar
I have the same problem, but haven't worked to fix it, if it can be. I bought the matched set of door locks, ignition, and glove box from classic. The tumbler comes out, the glove box is stuck locked, and the door lock button rusted right away. Disappointing!
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 11-14-2011, 06:53 AM   #5
63sbssbbw
UCA63
63sbssbbw's Avatar
Yes, it will all come out as a unit
T
member#7816
'61 GMC in progress
Old 11-14-2011, 04:27 PM   #6
Harley1650
Harley1650's Avatar
Thank you. I don't have a problem getting it out. My problem is it comes out all the time. I'll play around with it.
Old 11-14-2011, 04:47 PM   #7
brawley
Easy Does It
brawley's Avatar
after you have a paper clip in the small hole press in on it and then trurn the key. that will lock it in place.
brawley is offline   Reply With Quote
Old 11-14-2011, 05:01 PM   #8
Harley1650
Harley1650's Avatar
Awesome. Gonna fix it now
