Old 11-15-2011, 12:56 AM   #1
BossHogg69
motor exploder
BossHogg69's Avatar
Big Block Chevy cam, springs & pushrods
I have a Big Block Chevy (Mark IV) Comp XE294 cam (cam only, no lifters), Summit 1pc, .080" wall, 3/8" pushrods, and a set of Crower 68340 valvesprings for sale. The cam and pushrods have been installed, but never run, and the valvesprings have a few hours of runtime on them and are like new. The springs have been checked by a local machine shop (Rebel Rebuilders) are all are within spec. I changed over to a roller cam, so that's why I'm selling this stuff. Specs for everything are below. You can see what I paid for everything in the links provided below. I will take $220 SHIPPED!!!. First "I'll take it" gets it.
http://www.summitracing.com/parts/CCA-11-254-4/
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 2,800-7,000
Duration at 050 inch Lift 250 int./256 exh.
Advertised Intake Duration 294
Advertised Exhaust Duration 306
Advertised Duration 294 int./306 exh. .
Valve Lift with Factory Rocker Arm Ratio 0.588 int./0.593 exh.
Lobe Separation (degrees) 110
Grind Number CB XE294H-10
http://www.summitracing.com/parts/SUM-1439250/
Summit Racing Part Number SUM-1439250
For Use with Guideplates Yes
Pushrod Tube Diameter 3/8 in.
Pushrod Material Chromoly
Intake Overall Length (in) 8.280 in.
Exhaust Overall Length (in) 9.250 in.
One-Piece Pushrod Yes
Wall Thickness (in) 0.080 in.
Heat-Treated Yes
Quantity Sold as a set of 16.
http://www.crower.com/valve-springs-...amper-797.html
Summit Racing Part Number CRO-68340-16
Number of Springs Per Valve Dual
Outside Diameter of Outer Spring (in) 1.500 in.
Coil Bind Height (in) 1.080 in.
Damper Spring Included Yes
Spring Rate (lbs/in) 452 lbs./in.
Inside Diameter of Outer Spring (in) 1.120 in.
Inside Diameter of Inner Spring (in) 0.755 in.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-17-2011, 10:45 AM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Big Block Chevy cam, springs & pushrods
ttt
Adam
Old 11-17-2011, 06:17 PM   #3
bowtie72
bowtie72's Avatar
Man I wish the cam was a little smaller I would jump on that deal. I live at 7200 ft. I think it would be to much.
1968 SWB "Little White Truck"
1972 LWB LS 4l80 "Plain Jane!!"
bowtie72 is offline   Reply With Quote
Old 12-13-2011, 09:04 PM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
ttt for any Christmas shoppers...
Adam
Old 01-13-2012, 02:31 PM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
ttt for Friday the 13th!
Adam
Old 02-04-2012, 01:19 PM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
bump for the all those Valentine's Day shoppers... You KNOW your wife would rather have a hard hittin' big block over a little tennis bracelet!
Adam
Old 02-13-2012, 09:33 PM   #7
Critterman71
Critterman71's Avatar
TTT Would be sweet in my 402 for sure.
Critterman71 is offline   Reply With Quote
Old 03-11-2012, 04:18 AM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
ttt...
Adam
Old 05-07-2012, 11:18 AM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
ttt
Adam
Old 06-26-2012, 07:46 PM   #10
BossHogg69
motor exploder
BossHogg69's Avatar
anyone out there need any BB stuff?
Adam
Old 07-03-2012, 10:55 AM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
4th of July deal of the day! $220 - FREE SHIPPING anyone??
Adam
Old 08-11-2012, 04:25 PM   #12
BossHogg69
motor exploder
BossHogg69's Avatar
Ttt
Adam
Old 12-15-2012, 01:24 AM   #13
BossHogg69
motor exploder
BossHogg69's Avatar
ttt for xmas
Adam
Old 12-15-2012, 03:43 AM   #14
bk2life
seperate peices?
that cam is a bit big for some of our "street" motors..
bk2life is offline   Reply With Quote
Old 12-15-2012, 11:44 AM   #15
BossHogg69
motor exploder
BossHogg69's Avatar
What piece(s) did you have in mind?? Yeah, it's a stout cam. Should put a well built 454 (or bigger) well over the 550 hp range with a good set of heads.
Adam
Old 02-11-2013, 12:50 PM   #16
BossHogg69
motor exploder
BossHogg69's Avatar
ttt for tax refund season!
Adam
Old 02-15-2013, 05:16 PM   #17
BossHogg69
motor exploder
BossHogg69's Avatar
ttt for the weekend
Adam
Old 02-25-2013, 07:49 AM   #18
BossHogg69
motor exploder
BossHogg69's Avatar
reasonable offers?
Adam
Old 05-04-2013, 07:56 PM   #19
darkhorse970
darkhorse970's Avatar
Would you seperate the package and take $50 for the push rods.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 05-04-2013, 09:47 PM   #20
BossHogg69
motor exploder
BossHogg69's Avatar
I would separate the pushrods for $60 and you pay shipping.
Adam
Old 06-16-2013, 10:13 AM   #21
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Is everything still for sale? Please say yes, lol.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 06-17-2013, 08:10 PM   #22
BossHogg69
motor exploder
BossHogg69's Avatar
Yep, still have every bit of it.
Adam
big block, big block chevy, camshaft, comp cams
