Old 12-23-2011, 04:18 PM   #1
ChickenLeggs
Heater Issues
I've got a 1970 c10 longbed. The blower motor for the heater sounded like it had a bad bearing or was just shot. So I took the box assembly off the fire wall and replaced the blower motor and now I got nothing. The heating core is still getting hot, I just can't get the fan to turn on. I've checked the fuzes and they look good. Just looking for some help here. Not sure what else to do.
ChickenLeggs is offline   Reply With Quote
Old 12-23-2011, 06:16 PM   #2
Gumby
Gumby's Avatar
Re: Heater Issues
Theres a do-hicky things on the heater box or inside that gives you multi fan settings. Often it craps out with a new motor after many years.
mine went like that, I just give it a full 12volts and its like 5x more air then on high before and havent fixed it yet
dark n cold or I could take a pick of my do-hicky, cell phone has no flash.
Gumby is offline   Reply With Quote
Old 12-23-2011, 07:10 PM   #3
cdowns
cdowns's Avatar
Re: Heater Issues
did you check the new blower motor b4 you installed it to see if in fact it worked
Old 12-23-2011, 08:14 PM   #4
463
463's Avatar
Re: Heater Issues
is your ground wire put back on?
Trueman
463 is offline   Reply With Quote
Old 12-24-2011, 02:39 AM   #5
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: Heater Issues
Not to Hijack the post like some people suggest i do often But if you use a Blower fan from a AC unit that is ment for the AC unit and put it in a Heater only unit Dose it blow harder then the regular heater blower motor.
Lately I've been given a choice of buying the one that just has heater only not a Air conditioning truck and i made a mistake on my 1972 that just has the heater and man that mother blows so dam hard and in 5 minutes when i first start the truck on a cold morning its up to 165 degrees in the cab
One other thing I just broke the fan switch on my 1968 3 door suburban its the middle slider on a heater only unit on the dash.I had a friend of mine tell me he was tired of braking that middle leaver so he bought the AC one and the fan switch is on the side of the unit and is so much easyer to replace the one AC leaver that he dose not use he leave it alone and the unit works grate he had to install the regulator on the side of the glove box to control the speeds but he said it works flawless
Give me back any feed back on what he's done will it work and what are the hit and misses of using it
and again sorry to hi jack the post My one thing on what is wroung is look at your cables on your leaver see if there pushing the valve or the switch far enough over to makr it come on
stsalvage is offline   Reply With Quote
Old 01-20-2012, 02:00 PM   #6
workinprogress67
Re: Heater Issues
i think ur talking about the resister
workinprogress67 is offline   Reply With Quote
Old 12-24-2011, 03:52 AM   #7
MikeyMan
Re: Heater Issues
Check the ground.
Slightest miss in the connection will cause problems.
MikeyMan is offline   Reply With Quote
Old 01-20-2012, 01:36 PM   #8
ChickenLeggs
Talking Re: Heater Issues
Thanx for the help. It actually was the fuze, ooops. Sorry it took so long to get back to this thread. The heater worx to good
Old 01-20-2012, 01:42 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Heater Issues
The lever problem is an easy fix.Use the kit from one of the vendors to rebuild it.They use a steel lever whereas the originals are made of pot metal.While you're at it remove the cables and soak them in oil.I put mine in a parts washer to clean the old lube out,then I let them lay in the oil pan with oil from a change in it.clamped tham gently in a vise and worked them to free them up good then reinstalled.They've worked well for 15 years.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-20-2012, 02:04 PM   #10
workinprogress67
Re: Heater Issues
glad its solved
1970, blower motor, c10, heater
