View Poll Results: Which one should i do? | |||
EZ Wiring |
14 | 40.00% |
Hot Rod Wiring |
1 | 2.86% |
Painless Piring -Pickup |
18 | 51.43% |
Painless Piring -Street Rod |
0 | 0% |
A Member here has one for sale-+Contact info posted |
2 | 5.71% |
Voters: 35. You may not vote on this poll |
My Spoon Is Too Big
Complete rewiring
72 C20 LWB, elect fan, elect fuel pump, HEI, 90's serpentine belt system with internal regulated alternator, NON A/C, Cab...
Which one should i get? ez wiring http://www.ezwiring.com/wiring_harness.html hotrod wires http://www.hotrodwires.com/12Circuit.html painless wiring pickup http://www.shopatron.com/products/pr...er=10104/302.0 painless wiring street rod http://www.shopatron.com/products/pr...er=10102/302.0 forum member here has one for sale?
1972 C20, 03-14-10 Build Thread 2000 Silverado 4.8L, 11-04-13 (Currently Parting) 1999 Silverado 5.3L, 07-07-14. (Engine Donor) 2015 Ram 05-20-15 (Daily Driver) Last edited by dukkie; 01-21-2012 at 06:53 PM. |
![]() Join Date: Feb 2011
Re: Complete rewiring
I used the Painless 18 circuit part # 10206 http://www.shopatron.com/home/search...=10206&x=7&y=7 you will need to do some splicing and soldering, but it comes with extra circuits for power windows. fuel pump, fans etc.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
Moderator
![]() Join Date: May 2007
I would vote for American Autowire or M and H....but I do not see either in your poll
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I did a lot of reading/searches on this topic the passed few weeks. I came to the conclusion that AAWire was the way to go.
www.tomthetruck.blogspot.com <-- Aka build thread. |
![]() Join Date: Mar 2011
Ive used ez wire twice and painless once. Currently have a new ez wire that will go in the 68 when Im ready.
I think they are all good----and fairly easy to use----ez wire is cheaper and the quality is as good. |
![]() Join Date: Feb 2008
I'm going agree with LedZepp & Tmwoodall on the American Autowire too. I have been installing one of these in my 72 Burb using the truck version & it would be perfect for a truck. Very complete & gives you all the correct sockets to make it a near factory install. Also having each wire labeled every couple inches makes it real easy to install. It assumes HEI setup. Not the cheapest around $450 but well worth it.
Bryan '52 Bel Air 2dr HT - in pieces '68 C10 - 6cyl/4spd REMOVED, LT1/T56 to be installed “Any society that would give up a little liberty to gain a little security will deserve neither and lose both.” - Benjamin Franklin "And those who know what's best for us, Must rise and save us from ourselves" - RUSH lyric (mockery) |
#7 | |
My Spoon Is Too Big
If i knew of them i would include it too
1972 C20, 03-14-10 Build Thread 2000 Silverado 4.8L, 11-04-13 (Currently Parting) 1999 Silverado 5.3L, 07-07-14. (Engine Donor) 2015 Ram 05-20-15 (Daily Driver) |
out of curiosity..do these 'universal' kits come with plugs or pigtails that connect to all the accessories in the truck? like the ignition plug, gauge plug, headlight switch, wiper switch, etc. or do you have to reuse the ones you currently have(which seems kinda useless to have to use old connecters). I know some kits come pre terminated, others are more bulk. just curious what others are doing when it comes to the connecters.
#9 | |
Mike Redpath |
#10 | ||
My Spoon Is Too Big
And to understand yall correctly you are saying AAW includes new ones with their kit?? in addition they throw in a headlight and ignition switch as well?
You really should be looking for a wiring harness that has the circuits for everything you will be needing. A 12 circuit wiring harness is just the bare minimum. You should look it at least an 18 circuit wiring harness. I used the Painless wiring harness made for our trucks. It has the correct connections included. I used the 18 circuit truck wiring system (1967-1972) part # 10206. I installed it close to 10 years ago and have had no issues with it. Jegs has it for $388.00!
http://www.jegs.com/i/Painless-Perfo...d=#moreDetails Good luck! Keith Last edited by lil hoodlum; 01-21-2012 at 07:45 PM. Reason: mispel |
Painless 18 circuit as mentioned by keith. Take Your time and it will turn out great. i got mine from jegs with a 100 dollar rebate from painless. it was well worth it.
BlahBlahBlah
I vote for American Auto Wire also. Ive never seen such a nice complete kit before.
I used the painless 18 curcuit on my truck but i wish i had not. It has extra wires for everything which is nice but i dont have any of that stuff so now i just have a bunch of unused wires. The harness was not bad i just didnt get the right one for my use.
#15 |
AAW uses multi plug connections for all those extra circuits, so if you do not use them you do not have 20 feet of wire to cut off or roll up under the dash. I hope you terminated all the unused wires or pulled fuses to kill power to them
Mike Redpath |
#16 |
2WD Jimmy
![]() Join Date: Mar 2005
AAW.... period
#17 |
454 MAKES IT ROAR
Dukkie, I'd vote AAW too man, it's what i'll use when the time comes...heard only god things about them.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
#18 |
My Spoon Is Too Big
the poll is tied 5 to 5 EZ Wiring and Painless -Truck with zero votes on the others.. Sounds like had i known of and included American Auto Wire they would be at 7
#19 |
AAW sounds so complete, neat and easy. I see you're local. Are you doing the install yourself or having someone do it?
This is what sold me on the AAW kit. I don't have it, yet, but will be buying their kit soon. |
#20 |
I'd also go with American Auto Wire their wiring is superior to all the rest they use haevy duty wire and connectors plus you can buy direct from them and cut out the middle man.
www.americanautowire.com I used their harness to repair the A/C harness and you can see the difference in quality. |
#21 | |
#22 |
BlahBlahBlah
I bought my AAW kit from a board vendor and saved money over buying it direct. And yes the kit comes with headlight switch and ignition switch (with new keys). So you may to have your doors rekeyed if you want to run the same key on everything.
Cant remember which board vendor I bought it from >=(
#23 |
American Autowire part#510089.
Rockauto usually has the best price. |
#24 | |
My Spoon Is Too Big
thats the most important part CG!!!!! was it Musclerodz?
1972 C20, 03-14-10 Build Thread 2000 Silverado 4.8L, 11-04-13 (Currently Parting) 1999 Silverado 5.3L, 07-07-14. (Engine Donor) 2015 Ram 05-20-15 (Daily Driver) Last edited by dukkie; 01-23-2012 at 03:51 PM. |
#25 |
![]() Join Date: Jan 2001
Unless you want to take it in the shorts *no pun intended* go with any company OTHER than Painful Products.
my $.02 |
Tags |
circut, fuse, wiring |
