Additional VIN Locations
My grandpa swapped a 1985 2wd 1/2 ton body onto a 1976 3/4 ton 4x4 Chevy frame when he owned my truck... 3 years ago when I bought it from him i noticed the registration had the 1985 GMC VIN on it....
Does anybody know how I could recover a VIN number off the frame of my truck? I looked around and I couldn't find the full VIN anywhere... Thanks!!!
Rich My first truck!! ![]() |
Re: Additional VIN Locations
Yes - top side of the upper horizontal flange of the frame rail, midway along the frame (like in the vicinty of where the seat would be). The only thing is I can't remember if it's on the driver's side or the passenger side rail. I wanna say passenger side.
The next time someone corrects me on this I will make sure and write it down. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Now - to answer the question you didn't ask - if it's registered as the 85, as a result of the newer cab being used - it might be best to leave well enough alone.
I wouldn't recommend you try re-registering it to the '76 VIN or anything like that. K
Thanks! So I would have to take the cab off to see that VIN, correct? I was going to decode the VIN to find some out about the 76. Thanks for all the info!
#5 | |
No No
No you can see it with the cab on i can see it in my head but man i cant remember where the exact location is. Im going to throw it out there but i wanna say if you look around where the e-brake hooks are your going to see it. I havent been under my truck in a year so memory gets fuzzy... dont tell anyone havent changed my oil in a year ![]()
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
#6 | |
![]() ![]() So is the VIN on the very top of the frame rail? And is it the complete VIN? (All 17 letters/numbers?) Thanks!!
#7 | |
K
I've got a 79, and the vin on the frame is NOT a complete vin. Mine has the first letter (I'm assuming to tell the difference between a GMC and a Chevy frame, because if the cab wasn't attached, how would you know?) and the last 8 letters, which is the year, the assembly plant code, and the then the last six sequential serial number.
This was also similar to other GM trucks I found in the junkyard. I've never seen a complete VIN on a frame. |
On my 79 GMC it's stamped on the top of the passenger side frame rail about a foot behind the cab. I think it's the full vin but I will check tomorrow.
Thanks for all the replies! Hopefully this weekend I can find the time to check the frame rail for the VIN number. I'll let you know what I find!
Tags |
frame, vin |
