Old 02-06-2012, 04:58 PM   #1
76/85 Truck
76/85 Truck's Avatar
Additional VIN Locations
My grandpa swapped a 1985 2wd 1/2 ton body onto a 1976 3/4 ton 4x4 Chevy frame when he owned my truck... 3 years ago when I bought it from him i noticed the registration had the 1985 GMC VIN on it....
Does anybody know how I could recover a VIN number off the frame of my truck? I looked around and I couldn't find the full VIN anywhere...
Thanks!!!
Rich
My first truck!! 1976 Chevy 3/4 ton Camper Special and a 1985 GMC body. Has a 350, 4 BBL Edelbrock, with a Turbo 350, and NP205 T-case.
76/85 Truck is offline   Reply With Quote
Old 02-06-2012, 05:34 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Additional VIN Locations
Yes - top side of the upper horizontal flange of the frame rail, midway along the frame (like in the vicinty of where the seat would be). The only thing is I can't remember if it's on the driver's side or the passenger side rail. I wanna say passenger side.
The next time someone corrects me on this I will make sure and write it down.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-06-2012, 05:36 PM   #3
Keith Seymore
Now - to answer the question you didn't ask - if it's registered as the 85, as a result of the newer cab being used - it might be best to leave well enough alone.
I wouldn't recommend you try re-registering it to the '76 VIN or anything like that.
K
1979-1986
1986 - 2019
Old 02-07-2012, 10:11 PM   #4
76/85 Truck
Thanks! So I would have to take the cab off to see that VIN, correct? I was going to decode the VIN to find some out about the 76. Thanks for all the info!
Rich
Old 02-07-2012, 10:20 PM   #5
SSC's76
No No
SSC's76's Avatar
No you can see it with the cab on i can see it in my head but man i cant remember where the exact location is. Im going to throw it out there but i wanna say if you look around where the e-brake hooks are your going to see it. I havent been under my truck in a year so memory gets fuzzy... dont tell anyone havent changed my oil in a year
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 02-07-2012, 10:49 PM   #6
76/85 Truck
I went almost a year without changing mine, but then again mine has a "self-changing oil system". It used to leak/burn (the valve umbrella seals are bad) about a quart every 2-3 weeks. So I just add accordingly.
So is the VIN on the very top of the frame rail? And is it the complete VIN? (All 17 letters/numbers?)
Thanks!!
Rich
Old 02-08-2012, 06:50 AM   #7
Keith Seymore
Thanks!!
Yes; and yes.
K
1979-1986
1986 - 2019
Old 02-08-2012, 10:17 AM   #8
SSC's76
No No
SSC's76's Avatar
with part of a nights sleep also remember there is a vin on the radiator support as well.
Old 02-08-2012, 01:41 PM   #9
76/85 Truck
Originally Posted by Keith Seymore View Post
Yes; and yes.
K
Thank you!!! I'll check next time I'm under the truck... I wish my grandpa would have kept the 76 body even though it was covered in rust... I would like to know the RPO codes listed in the jockey box...
with part of a nights sleep also remember therhttp://67-72chevytrucks.com/vboard/images/smilies/gmc2.gife is a vin on the radiator support as well.
I think the core support is from the '85... he replaced the front clip, cab, and box. I'll check it out.. Thanks!
Rich
Old 02-08-2012, 08:59 PM   #10
Keith Seymore
Not that I'm aware of.
What are you thinking of? Is there a label (like the emissions label) or are you thinking of stamping?
K
1979-1986
1986 - 2019
Old 02-08-2012, 10:09 PM   #11
SSC's76
No No
SSC's76's Avatar
K
It's stamped on mine. I will snap a picture if i decide to open my hood anytime soon
Old 02-08-2012, 10:28 PM   #12
wilkin250r
wilkin250r's Avatar
I've got a 79, and the vin on the frame is NOT a complete vin. Mine has the first letter (I'm assuming to tell the difference between a GMC and a Chevy frame, because if the cab wasn't attached, how would you know?) and the last 8 letters, which is the year, the assembly plant code, and the then the last six sequential serial number.
This was also similar to other GM trucks I found in the junkyard. I've never seen a complete VIN on a frame.
wilkin250r is offline   Reply With Quote
Old 02-08-2012, 11:42 PM   #13
old yelr
On my 79 GMC it's stamped on the top of the passenger side frame rail about a foot behind the cab. I think it's the full vin but I will check tomorrow.
old yelr is offline   Reply With Quote
Old 02-09-2012, 11:31 PM   #14
76/85 Truck
Thanks for all the replies! Hopefully this weekend I can find the time to check the frame rail for the VIN number. I'll let you know what I find!
Rich
frame, vin
