dodge dana 44 on a c30?
i bought a dana 44 out of a dodge d250 its all there with springs and all steering stuff.
would it work under my 75 c30? since its the same lug pattern it wont be offroaded very hard |
Re: dodge dana 44 on a c30?
and im going to use dually hub spacers so i dont have to buy new wheels
Sounds good, the only thing to watch out for is that the spring pad width for Dodge is 1/2" wider than Chevy.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
so could i just weld on new spring perches 1/2" closer in? and the steering will still work with stock 2wd steering box?
#5 | |
![]() Last edited by mknittle; 02-09-2012 at 11:53 AM. |
I'm confused. Is the Dana 44 a front axle? Do you have a C30 or a K30? If it's a C30,is it converted to 4wd? If it's converted to 4wd,do you have crossover steering? Is that why you have a 2wd steering box? Because a 2wd steering box won't even work in a stock 4wd. As far as a Dodge axle into a GM goes,the spring pads need to be moved inward. If you are in the process of converting a 2wd into a 4wd you could probably set it up so the springs are spaced for the Dodge axle,if it's all custom anyway.
The dodge D250 and D350 series were 2wd.
The dodge W250 and W350 series were 4wd.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
#9 | |
and itll be all custom i just need the money |
Ok,the leave the axle alone and just mount the spring hangers where they need to be. No sense in altering the axle when you have to fab/install spring hangers anyway. And,I know what you mean about money.
Yeah you can cut the spring perches off and weld new ones on in the right place.But if you want a big lift or big tires i would look for a dana 60.
Just mount the axle up. The half inch difference doesn't not effect anything. I know dieselwrencher has done this with a dodge d60 and it is fine. I have also read about other people that did this as well. It will bolt right in.
Posted via Mobile Device I forgot you are converting the truck to 4x4 If your going to build the mounts then work in the half inch. But if you just steal parts off a 4x4 to convert it then don't worry about the half inch.
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
#13 | |
Local Redneck Authority
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
#14 | |
![]() Join Date: Aug 2008
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#15 |
#16 |
If you use factory 4x4 setup most guys including myself don't worry about the extra 1/2". We simply bolt one side up and then put a port-a-power or bottle jack between the springs and spread them until the center pin on the other side drops into the pad. Then tighten down the U bolts and release the pressure from the jack. This is the redneck way to use a Dodge front axle in a Chevy.
#17 |
so it should be fine?
#18 |
If you use stock 4x4 brackets it will be fine. If you build your own brackets then you might as well add in that half inch.
#19 |
oh ok i was just gonna make my own
#20 |
oh ok cool. i might be changing my plans tho this guy wants to sell me his 77blazer with 3/4 ton running gear for $600 could i use it? i wanna swap to srw i found a clean bed and tailgate for $100
#21 |
Yes you can everything will swap over.
#22 |
Yeah,that'll work and much better. When spreading GM springs to fit a Dodge axle you can only "hope" the axle sits centered.
#23 |
well no blazer for me. couldnt get the money. im thinking just buy stock mounts and a chevy axle or just save up and buy a k20 or k30
