Old 02-08-2012, 01:54 PM   #1
77c10
77c10's Avatar
77 C10 LT1 power steering question
I have a 77 C10 2wd with a LT1 crate motor in it. I want to add power steering to the truck. Currently the only accessory I have is the alternator and it is mounted low and to the left of the motor with a single belt that is driven off the crank pulley. My question is, can I get a stand alone bracket to mount the power steering pump and if so, are there double bottom pulleys available to run the PS pump?
Thanks!
77c10 is offline   Reply With Quote
Old 02-08-2012, 10:29 PM   #2
superwade57
Re: 77 C10 LT1 power steering question
is this a second gen lt1? if so you can get an accessory bracket and factory ps pump from any early to mid 90s b body car impala caprice roadmaster, or camaro trans am which has a little different acc set-up im gonna do the swap soon my only ? is is the powersteering pump strong enough for our trucks?
superwade57 is offline   Reply With Quote
