Old 02-22-2012, 02:58 AM   #1
slick78
350 heads
So i replaced the heads on my 350 cause they were both cracked, and i bought some camel hump heads off a guy i know. I take to the machine shop to get them checked and cleaned up. They were good and ready to go, then the owner of the shop says they wont work cause they dont have the holes in the front of the head to bolt on my accesories. So what do i do? Buy brackets to fit my truck or get other heads? Please help. Also, on one head. Someone drilled 2 holes in the front of the head but i dont know for what. Can i just weld them shut or plug them up with short bolts?
slick78 is offline   Reply With Quote
Old 02-22-2012, 03:44 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: 350 heads
Do you have ac? You can drill the heads for accessory holes if you need to. Any competent machinist can do this. Camel hump heads arent to hard to get rid of. There are two versions of the camel hump 202. One has bolt holes and the other version which you have doesnt
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-22-2012, 03:57 AM   #3
74 stepside
74 stepside's Avatar
Re: 350 heads
Try www.alangrovecomponents.com they make all kinds of custom brackets. Otherwise you might have to sell your heads and get different ones.
74 stepside is offline   Reply With Quote
Old 02-22-2012, 04:34 AM   #4
TheCustomFactory
TheCustomFactory's Avatar
Re: 350 heads
If you run a long water pump with just a alternator and powersteering its easy. Only the lower alternator bracket uses an accesory hole so instead of using that long bolt and spacer just use a bolt and nut. It works great.
TheCustomFactory is offline   Reply With Quote
Old 02-22-2012, 11:34 PM   #5
slick78
Re: 350 heads
So many options and ideas. I need to get this truck running cause iam moving. What would u guys do? My wife and her fam own a metal fab shop. Can i just have them make something?
Old 02-23-2012, 04:23 AM   #6
7.62
Re: 350 heads
I made the same mistake, put mine up on Craigslist and a local race guy swapped me for some that had bolt holes and actually were nicer than the ones I had. Might try it, ya never know.
7.62 is offline   Reply With Quote
Old 02-23-2012, 11:26 AM   #7
zac
zac's Avatar
Re: 350 heads
67-72 low-mount power steering pump and bracket. I also found a low mount power steering set up on a '74 G20 van that works. Frame clearance is tight, may require a little tweaking. Many street rod style alternator brackets will work. With the correct rams horns exhaust manifolds the vette style alternator bracket (60's?) may be an option.
zac is offline   Reply With Quote
Old 02-23-2012, 12:58 PM   #8
slick78
Re: 350 heads
Yea i was told about going this route, it might be the easier way. Iam sure i can find the brackets at a junck yard. That answers that question. Thanx guys! Once again u guys helped out.
