Old 02-23-2012, 01:19 PM   #1
franky69c10
chevy runs deep
franky69c10's Avatar
wheel hop when braking ?
Just would like to know what u guys think what can cause the passenger wheel to hop when I slow down could it b the tie rods ?
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 02-23-2012, 01:23 PM   #2
rwhit57
rwhit57's Avatar
Re: wheel hop when braking ?
I'm not sure what you mean by hop, but if the rotor is warped that could cause it to feel pretty rough.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 02-23-2012, 01:41 PM   #3
franky69c10
chevy runs deep
Not its not the rotor there fine, its like when im slowing down the wilk start to wobble/hop then the whole truck start shaking so I gotta stop all the way for it could stop shaking
RAIDER NATION
My LWB is a SWB now
Old 02-23-2012, 01:54 PM   #4
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
My truck bounches up and down braking at 45+ and anything under it shakes like a freezing bird. I know that I need to have new control arm bushings put in because mine are bad. When I replaced the pads the rotors seemed okay. Not sure though. Subbed.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 02-23-2012, 02:17 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
if the rotor isnt warped check your rubber line and caliper.. its something in that front brake other thing ive seen is if the wheel bearing nut is too tight that that will happen
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-23-2012, 02:50 PM   #6
68Timber
I know the pieces fit
68Timber's Avatar
Classic worn shock symptom.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-23-2012, 03:12 PM   #7
franky69c10
chevy runs deep
New shocks in the front
RAIDER NATION
My LWB is a SWB now
Old 02-23-2012, 09:23 PM   #8
DetroitIron
DetroitIron's Avatar
My thought as well
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
Old 02-23-2012, 03:14 PM   #9
THE "10" SILVERADO
My shocks are so old I doubt I can even call them shocks anymore.
Michael
Old 02-23-2012, 03:31 PM   #10
rwhit57
rwhit57's Avatar
I would check all the front end components, tie rods, idler arm etc. something is loose. Get under it and have someone move the steering wheel back and forth slowly. If somethings worn out you should be able to spot it.
Old 02-23-2012, 03:34 PM   #11
Goldfinger
Goldfinger's Avatar
Mine had a wheel hop when i shattered my pad.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 02-24-2012, 10:33 PM   #12
DetroitIron
Let us know when you solve it
Old 02-24-2012, 11:24 PM   #13
THE "10" SILVERADO
Just a question guys, when someone says you need a front end rebuild what necessarily does that mean? I know that my control arm bushings are bad but a family friend that is a mechanic said I'd probably need a complete front end rebuild. I'm going to try to start buying the necessary parts but besides control arm bushings what else is required?
Thanks.
Michael
Old 02-24-2012, 11:54 PM   #14
3r!c84
Badass
3r!c84's Avatar
Jack the frot end up. Shake the tires. Left and right and up an down. See what parts you new to replace.
Remember after front end work needs an alignment..
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 02-25-2012, 07:22 AM   #15
Phillip Pennartz
things to check for wear on front suspension
upper and lower ball joints
inner and outer tie rod ends
idler arm
pitman arm
steering box
I cant remember if center link has a joint in it but
if it does it will need checking also
shocks
might just take it to alighnment shop for free estimate. call to make sure
its free first
Phillip Pennartz is offline   Reply With Quote
Old 02-25-2012, 08:03 AM   #16
big10ratrod77
big10ratrod77's Avatar
do you feel eny vibration in the brake pedal when stopping? thats a dead give away for a warped rotor. it could be a sticking piston in the caliper also. BUT before you start throwing parts at it check everything over realy good first.
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 02-25-2012, 09:17 AM   #17
old Rusty C10
a rebuilt front end consists of control arm bushings, bump stops, tie rod ends- inner and outer, ball joints , idler arm, pitman arm, and centerlink.. in these trucks the centerlink is solid metal and seldom goes You can add front shocks and springs in that mix too
Bob
I hate cancer!!
Old 02-25-2012, 10:50 AM   #18
THE "10" SILVERADO
I have been looking into a compete front end kit from PST suspension. Besides this kit (http://www.p-s-t.com/s.nl/it.A/id.116/.f?sc=12) what else would I need to get?
Michael
