Manual rack (MS II type), who is using these?
Folks,
I now have a power rack, but don't have the truck on the road yet and was considering going to a manual one....anyone using a manual one (who thinks that is the way to go)? Posted via Mobile Device |
Re: Manual rack (MS II type), who is using these?
I don't have mine on the road yet either but I put in a power rack so I can use a smaller steering wheel.
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
if you run skinny tires up front i think the manual would be fine
I think you will be much happier with a power rack and pinion !!
#7 | |
There is plenty of room for a pump, and you can get high pressure hose and fittings at Don.s,, take the rack and Jay will set you up for the fittings and route the hoses in a clean manner, go for it you will like to drive your truck
#8 | |
I will likely keep it, but wil put the pump and hoses together myself...who is jay? Posted via Mobile Device |
#9 | |
They have the fittings that will fit the rack and PS pump, If you do not have anything for your plumbing. When you are placing the high pressure line on the rack be sure to ID the high pressure inlet on the rack, you do NOT want to get them backwards
I have a manual rack i got with my mustang II kit. I will be putting it in within the next couple months and will let you know how it goes. I bought it for a clean simple install so no hoses clutter the engine comp and it was cheaper lol.
I'll be running 15's up front with a 225 or 235 |
#12 | |
#13 | |
I'm the same way just looking for clan clutter free install |
#14 | |
#15 |
I have never used them at all. I do alot of my work myself and my brother helps me at times cause he has a small shop. I've seen there shop, greats products and work. They said they could help me install my front end and gave me a great price i may take them up on
#16 |
I would keep your power rack in your truck you will be much happier with it.When you make those right and left turns you will be glad you kept it in your truck.
Justin |
#17 |
i had a manual rack in my 63 ford truck. it turned real easy. i wouldnt be afraid of them
#18 |
Just put a 283 and MII with manual rack in my '48 in Dec. Don't mind it at all. But I also have the original steering wheel. I can see where power would be good with a smaller wheel
#19 |
I still wanna build a truck with power steering as well cause there are those times it makes all the diff in the world
#20 |
Dieselwrencher: I have heard some info like that and interested to see how mine turns out.
Indy Bowtie: You have a valid point there too |
#21 |
I have power steering on my 54 with a big block. My steering is very sensative. I have been told to switch to a 79-93 mustang R&P because it is less sensative. Other than that I love the power steering. If you use a 79-93 rack be advised it is 15 1/2" center to center. If you have an older crossmember you will need to use off set bushings. The new racks have a slot in them so they can use either the 74-78 or the 79-93. NAPA part # is 22-203-F for the newer rack. This is the one that has 2 3/4 turns lock to lock. Hope this helps.
#22 |
The rack you want to use is a 88 t-bird power rack
#23 |
To Scotts Hot Rods, why is that the one to use over the 79-93 Mustang. Is it 16" center to center? I have a Fatman crossmember and I used V8 springs with one coil cut out. Now after 500 miles the bottom A frames are 2" above the rack. What springs should I use and should I get some 2" drop spindles also? I am not far from your shop and have talked to you before about other things. Perhaps you can give me some suggestions. Thanks
#24 |
The power racks we have been useing for several years have been and will always be based on a 88 t-bird
1.Designed and will work with a gm pump no problem at all 2.Not as sensitive as the mustang power racks out there 3.Deisgned to work with a heavier car or truck 4.Now at this time the power racks we have are BRAND new not reman racks. These just came available to us a little over two months.The best thing on these new racks they come with LIFETIME warrantty so you buy once and never again. The price on these to buy are $389.00 and come with rack bushings and these have a lifetime warrantty to.You cannot go wrong at all. 5.The power racks at all the parts stores are not brand new at all.They are based off the mustang which had over 17 different power racks you can get at parts stores. 6.The mounting points on our power racks we use are 15 1/2 spread and they even come with the power rack fittings.This means no more messing up the threads at all. 7.The last thing if you are in Moorpark you are more than welcome to come on by and you can take a look at these power racks we have here in stock and you will be shocked on how they look compared to the others on the market. Justin |
#25 | |
