Old 03-31-2012, 11:12 PM   #1
solidaxel
solidaxel's Avatar
Re: Manual rack (MS II type), who is using these?
Originally Posted by vjjack04 View Post
Just don't want it to be too free...but I have the power rack so I may keep it.
Check that power rack that came with the front end, and tell me how many turns you have from lock to lock.
There is plenty of room for a pump, and you can get high pressure hose and fittings at Don.s,, take the rack and Jay will set you up for the fittings and route the hoses in a clean manner, go for it you will like to drive your truck
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-31-2012, 11:23 PM   #2
vjjack04
vjjack04's Avatar
Thanks,
I will likely keep it, but wil put the pump and hoses together myself...who is jay?
vjjack04 is offline   Reply With Quote
Old 04-01-2012, 07:54 AM   #3
solidaxel
solidaxel's Avatar
Thanks,
Jay works at Don's Hot Rod shop in Tucson on Stone Ave.
They have the fittings that will fit the rack and PS pump, If you do not have anything for your plumbing.
When you are placing the high pressure line on the rack be sure to ID the high pressure inlet on the rack, you do NOT want to get them backwards
LS 3 4L70E
Old 04-01-2012, 06:27 PM   #4
vjjack04
vjjack04's Avatar
thanks - i appreciate the info.
