Old 04-10-2012, 11:07 AM   #1
dragtruck
Info needed on both lowering and seat belts
I have a '72 GMC half ton with factory rear leaf springs. I want to lower the rear 2-3 inches. Can I just remove a leaf and if so, which one? I'm thinking maybe the second one from the top.
I also want to install 3 point seat belts. My truck only has lap belts, but it does have the mount welded in for the upper third point. Can I buy the complete set of belts from a newer truck? Thanks.
dragtruck is offline   Reply With Quote
Old 04-10-2012, 04:18 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Info needed on both lowering and seat belts
ttt
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-10-2012, 08:10 PM   #3
Tuff Gong
Tuff Gong's Avatar
I know you can buy aftermarket 3 point belts from places like LMC. I think there is even a nice used set for sale on the board right now.
Tuff Gong is offline   Reply With Quote
Old 04-10-2012, 09:17 PM   #4
Yooper truck
Yooper truck's Avatar
I have a 71 C-10 Longbed with leaf springs.
Seat Belts.... I put aftermarket 3 point in last summer. It was very easy and bolted right in to the upper anchor.
Springs.... I replaced mine because a previous owner tried lowering by heating and bending the end of the springs. It then rubbed the cross braces on the box. It was a guessing game to get it the desired height. It is a lot easier working with the springs with the bed off, but then it is hard to visualize the height of the back of the truck.
Yooper truck is offline   Reply With Quote
Old 04-11-2012, 09:47 AM   #5
KyFarm
KyFarm's Avatar
i bought the 3 point belts from lmc and they bolted in easily and work fine. However the short belt with the "female" end is too long and ends up hitting me in the middle of my stomach instead of down around my hip.
So I just cross over the passenger and driver short belts. Meaning i buckle into the passenger side and the passenger uses the driver side. Works great!
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 04-11-2012, 12:28 PM   #6
Ackattack
Ackattack's Avatar
I lowered my 72 GMC by removing 1 or 2 leafs (it was awhile ago, so I don't remember how many or which ones). However, when I took it to the drag strip, I had terrible wheel hop and ended up shearing off the rear u-joint. I attribute this to the missing leafs.
They do make some drop shackles, but I don't think it will lower it much. On my 69 GMC, I switched to a trailing arm/coil spring setup with 4" lowering springs.
Ackattack is offline   Reply With Quote
Old 04-11-2012, 10:19 PM   #7
Hubscrub
Cruzin
Hubscrub's Avatar
try here for belts my wife has some in her 67 http://www.seatbeltplanet.com/ she has the non retractable
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
