Fuel gauge install
OK guys, I got my gas gauge and going to try and install it this weekend. My question is should I drop the tank or pull the bed to gain access to the sending unit? And should I change the sending unit while I'm there? The gauge hasn't worked in a long time. My thinking is while I have everything down I should go ahead and change the sending unit as well. Do you all agree?
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
Come on guys, I need to know something by 4pm CST to see if I need to borrow the lift from work or not.
Well,
Dropping a tank on one of these isn't very hard if you're low on gas. Otherwise, it gets ... heavy. Plan on replacing your tank straps while you're at it. Most of the time the welded-on bolts are so rusty that they have to be cut. Brian |
"The dude abides"
I would say drop the tank. And since you have it down, if you have the dough, I would put in new sender to.
RockMan 1993 Chevy Silverado C3500 1 ton dually 1994 Honda Civic 1969 Oldsmobile Cutlass S 1953 IH Farmall Super M New to the fleet: 1992 Subaru Loyal |
"The dude abides"
PS I would install a new filter on it also. I believe it is actually the pickup screen, but since you have it all out, might as well do that to.
I'm back with 2nd truck!
I agree. Drop it, clean it out and install a new sender with new hoses. If you had the $$$ I'd change to a poly tank.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
While the tank's out look inside & see how much rust it has in it.
Went pretty smooth! Dropped the tank, not too bad. Got it together and was going to get gas. Pulled out of my driveway and ran out of damn gas. I ran it low, so I could drop the tank. Luckily I had a gas can with me. Made it to the store and 15.59 gallons in the 16 gal tank. Cranked it up and the needle went to Full. Yesssss!!!!! I will get some pics of it ASAP!!
LED King
Score! Congrats on a good job! YES pics please!
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
Here is the pic of the gauge.
#11 | |
www.loweredd.com
Where can you get a poly tank at? |
#12 | |
You know you want to ![]() Looks good, I need to get into my tanks and figure out whats going on. I probably need new sending units and a switching valve. $$$$$
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
big block lover
changing my tanks soon also!
gary,
did you remove the bed...or did you just drop the tanks... what procedure did you use...i looked at the tanks on my 81 and it looks like i need to remove the bed....i cant get my big hands to the bolts on the straps! damn.
81 custom deluxe lwb 454 bored .030 over w/ small RV cam. 2.5 exaust- thrush turbo muffs. th350 getting beefed up soon! |
#14 | |
