Rusty Nuts
I have an issue with cab mounts
I guess I have the C20 cab mounts (first pic) I have cab I am sitting on a 4 wheel frame. So do I need regular C10 cab bushings (second pic) I am really confused on what to get now. When I got these this is what the vender said I needed. First pic. Any help would be great. Oh and it is just a 1/2 ton frame. And if they are supposed to the first pic, which ones go to the front of the cab.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 Last edited by Mr Chevorlet; 07-16-2012 at 11:48 PM. |
Re: I have an issue with cab mounts
I am a little confused as to what you are exactly assembling together, in regards to what cab on what frame. It does sound like you need the 1/2T bushings though.
Are you putting a cab on a 1/2T 2wd frame? Travis |
Rusty Nuts
It is a 1972 4 wheel drive 1/2 ton frame that I am sitting a 1967 cab on it.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
A four wheel drive frame uses the mounts shown in the first set with the taller mounts. The front cab mounts are the on the right side of the picture second set.
Here is a picture of the front mounts installed. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Rusty Nuts
I guess i have my special helmet on, but you said i will need to use the first set of mounts shown with the taller mounts for the four wheel frame but then you said to use the smaller bushings in the second picture for the front of the cab. them are for a 2 wheel drive frame.
So do i use the short mounts in the first picture for the front and the taller ones on the back
![]() Join Date: Dec 1999
You need the first picture set for a 4X4
'67 C20 LBW |
Rusty Nuts
Thanks for the replies i got the cab on but now the cab is riding on the transmission. sorry i opened another thread on this. sorry guys
