08-27-2012, 01:22 PM | #1 |
Bolt on Rack and pinion
Thought I would share for those that do not know. This kit is made by unisteer and is a true bolt on kit requiring no drilling! The product info is a little behind but the kit is now avail to fit 67-72 chevy trucks. They use the existing tie rod ends. The kit is avail without the pump and lines for 850.00. here is a link http://www.unisteer.com/search_by_pr...inion_kit.html
08-27-2012, 01:24 PM | #2 |
C/10 junkie
Re: Bolt on Rack and pinion
Wow that is way cool
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
08-28-2012, 02:56 AM | #3 |
Its about time they made one,flaming river has had a kit but its pricey and no limit has a kit but you have to use after market tubular control arms with it.
08-28-2012, 05:37 AM | #4 |
08-29-2012, 12:52 AM | #5 | |
08-29-2012, 05:44 AM | #6 |
I like this kit because it is appears to be true bolt on... Not knocking the no limit kit but its quite a bit more work to install it over this one from what I have seen. I have ordered one and will post install pics when I get it.
08-29-2012, 09:18 AM | #7 |
The more options for good aftermarket parts the better,I like no limits rack and pinion but your right im lazy that looks like more work then i wanna do lol.The last rack and pinion i put on was my mustang it was a bolt in kit didn't take me more then a hour.
08-29-2012, 10:15 AM | #8 |
Please post pics, I'm interested to see. The no limit kit was a fair amount of work but my truck is not a daily driver so if it's in pieces for a week (or two) while I chip away at projects I don't mind. I quite enjoy it.
08-29-2012, 10:49 AM | #9 |
I quite enjoy working and chipping away at it myself.... I like the idea of being able to unbolt and return to original state if needed, but that is just me.
08-30-2012, 11:30 PM | #10 |
Gmccanuck,
You should start a thread showing some pics of your no limit install. I am sure some would love to see the progress. I will be looking to install mine in the next couple of weeks. Posted via Mobile Device
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler 1968 Chevy c10 shorty Stepper (Patina LS project) 1967 gmc custom Long Box (Farm Truck Project) |
08-30-2012, 11:51 PM | #11 |
oh dear, putting my handiwork up for the whole world to see.....
I'm pretty much done, but I'll take a few pics and zoom in on a few details that gave me some grief. |
08-31-2012, 11:37 AM | #12 |
Just to be clear, our No Limit C10 rack and pinion will work with stock lower arms on 63-72 trucks. For the 73-87, tubular lowers are required. We recomend Porterbuilt Forward Lower arms. The problem is with the huge bushing and stamped arm on the stocker, there is no room for the rack. Swapping to the tubular arm also gives you a bit more ground clearance.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
09-06-2012, 08:47 PM | #13 |
The Rack kit came from unisteer yesterday... got started this afternoon. Got the rack bolted up. I simply removed the steering box, idler arm, and crosslink. The rack kit came assembled and bolts right in place of the steering box and idler arm..... so far no holes to drill and as you can see from the pics plenty of room on the lower control arms. It is still early but I am impressed with the fit so far.. I am installing this on an ls equipped truck so I am sure the steering shafts will require some work...... only time will tell.... Here are the pics so far
09-06-2012, 08:48 PM | #14 |
more
08-30-2018, 10:03 AM | #15 |
I'm looking at the Unisteer for my 67 C10. I'm swapping in an LS2+4L65E. Unisteer is telling me there are oil pan clearance problems with LS installs. Anyone have any experience with this?
Specifically, Unisteer is saying the hard lines on the rack have a clearance problem with the oil pan. They said JEGs has a steel oil pan, and that using that and raising the motor 1/2" will clear the pan. I just bought a new aluminum pan for the motor, and the pan is supposed to be a structural part of the LS motors, so I'm not really keen on swapping to a sheet metal pan. I think I spy an LS pan in Rob's install photo. Just wondering if others here have experience using the Unisteer kit with an LS swap. I'm currently using single piece adapter plates and the stock SBC perches and motor mounts. Thanks. |
09-06-2018, 08:09 PM | #16 | |
So rob will this work on a 76 with cupped lower control arms and a pancaked crossmember? Posted via Mobile Device |
09-10-2018, 08:29 AM | #17 |
I'm just glad to be here!
Only if the lower arms have been changed...the '76 lower arm bushing is still the issue.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
08-20-2021, 09:25 AM | #18 |
I know this is a long shot, but is the OP still around and able to give feedback on the POL R&P kit for long term usage?
09-07-2012, 10:03 AM | #19 |
awesome looking good.
Keep us posted I kept hoping somebody would post up some driving experiences on a rack and pinion any version but nobody seems to have one completed and want to give any input. This sounds like a great upgrade as I have done several to my truck but the upfront costs have limited me since I have to purchase it all at once. so far it looks good. Mine is ls equiped also
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
09-14-2012, 11:09 AM | #20 |
Hows the install going?
09-16-2012, 08:22 AM | #21 |
Haven't had any truck time this week, been working on the my house. I will post pics when I can work on it.
09-17-2012, 12:31 PM | #22 |
no worries, I understand on the house stuff. This will get done when you get done. I am just hopeful to hear some real world thoughts on how the rack and pinion stuff does on these trucks.
There seems to be alot of hype but I had not heard much input from an end user.
09-30-2012, 08:46 AM | #23 |
I finished my install yesterday..... I left the camera at the shop so it my be later in the week on pics. I installed this kit with an ls swap so the upper shaft needed to be a little longer. I called unisteer and they sent one right out. The only other modification I had to do was cut the shaft support bracket, reposition to clear headers and reweld. That way I could bolt it to the top of the motor mount just like they intended. I can return the truck back to original at any time by simply bolting the old stuff back on. The steering is very nice with a new car feel, at least in the short trip around the block I took. By far the easiest "bolt on kit" I have done on these old trucks
10-01-2012, 10:55 AM | #24 |
great news. I am glad the swap went well for you. After you get it all realigned let us know how it continues to do. I still want to do a swap just cant afford it right now..
10-01-2012, 11:17 AM | #25 |
I also would like to know how this does after you put a few miles on it. I plan on in-stalling one on my 67 soon.
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985 "The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945 |
