10-04-2012, 10:18 PM | #1 |
Need Advice On A lsx Engine
im looking at a 99 lQ4 with a 4l80E behind it i was wondering if it would be worth getting or should i look for a newer ls engine the engine will be used in a 78 gmc swb and be used as a dailiy driver any advice or tips would be helpful thank you
10-04-2012, 10:32 PM | #2 | |
Re: Need Advice On A lsx Engine
I would pass..... |
10-04-2012, 10:48 PM | #3 |
10-04-2012, 11:30 PM | #4 |
10-05-2012, 12:12 AM | #5 |
X2. The newer heads would work on it, but why bother when you can get a newer better engine? JMHO
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
10-05-2012, 12:37 PM | #6 |
Boosted Member
Depends on the price you can get it for. You can pick up aluminum 317s for next to nothing, and the rear crank flange isn't really an issue either.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
10-05-2012, 01:29 PM | #7 |
I would definitely get an lq4. lots of the parts are swappable. You can toss all of these on there and end up with a pretty sweet engine on the cheap
ls2 throttlebody l92/ls6 heads ls3/l76 intake (FAST is too expensive for me) lq9 pistons if you are staying NA
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
10-06-2012, 02:03 AM | #8 |
meowMEOWmeowMEOW
99's also had issues with the wiring, in terms of pcm compatability. If everything is together, and a good price then its worth it, otherwise there is ALWAYS another one.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
10-09-2012, 09:33 PM | #9 |
well i found a 03 lq9 for a good price but the guy has a 2001 4l80e from a lq4 and it has 175xxx miles on it would it be best to find a lower mileage one or rebuild it
10-09-2012, 10:08 PM | #10 | |
A 4L80E in a 1/2 ton truck with a stock engine is way overkill. If the internet had its way.....Everything would have a 4L80E in it |
10-10-2012, 01:28 AM | #11 |
meowMEOWmeowMEOW
yup
10-10-2012, 07:02 PM | #12 |
