Old 10-04-2012, 10:18 PM   #1
78gmc1
78gmc1's Avatar
Need Advice On A lsx Engine
im looking at a 99 lQ4 with a 4l80E behind it i was wondering if it would be worth getting or should i look for a newer ls engine the engine will be used in a 78 gmc swb and be used as a dailiy driver any advice or tips would be helpful thank you
78gmc1 is offline   Reply With Quote
Old 10-04-2012, 10:32 PM   #2
clinebarger
Re: Need Advice On A lsx Engine
A '99 LQ4 will have iron heads & a extended crank flange.
I would pass.....
clinebarger is offline   Reply With Quote
Old 10-04-2012, 10:48 PM   #3
78gmc1
78gmc1's Avatar
I would pass.....
would newer ls heads work on it?
Old 10-04-2012, 11:30 PM   #4
clinebarger
Yes.
Old 10-05-2012, 12:12 AM   #5
ls1nova71
ls1nova71's Avatar
I would pass.....
X2. The newer heads would work on it, but why bother when you can get a newer better engine? JMHO
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-05-2012, 12:37 PM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
Depends on the price you can get it for. You can pick up aluminum 317s for next to nothing, and the rear crank flange isn't really an issue either.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-05-2012, 01:29 PM   #7
Billett
Billett's Avatar
I would definitely get an lq4. lots of the parts are swappable. You can toss all of these on there and end up with a pretty sweet engine on the cheap
ls2 throttlebody
l92/ls6 heads
ls3/l76 intake (FAST is too expensive for me)
lq9 pistons if you are staying NA
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 10-06-2012, 02:03 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
99's also had issues with the wiring, in terms of pcm compatability. If everything is together, and a good price then its worth it, otherwise there is ALWAYS another one.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-09-2012, 09:33 PM   #9
78gmc1
78gmc1's Avatar
well i found a 03 lq9 for a good price but the guy has a 2001 4l80e from a lq4 and it has 175xxx miles on it would it be best to find a lower mileage one or rebuild it
Old 10-09-2012, 10:08 PM   #10
clinebarger
A '03 LQ9 is a great engine, Why a 4L80E? LQ9's have 4L65E's behind them.
A 4L80E in a 1/2 ton truck with a stock engine is way overkill.
If the internet had its way.....Everything would have a 4L80E in it
Old 10-10-2012, 01:28 AM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
yup
Old 10-10-2012, 07:02 PM   #12
clinebarger
Originally Posted by BR3W CITY View Post
yup
