Old 11-08-2012, 10:40 PM   #1
DoubleL
DoubleL's Avatar
Anyone with a 700r4 column shift
I currently have a cheap floor shift for my new 700r4 but would like to have a column shift. I was wondering if you could adapt a column from an auto truck of our years to accommodate the 4 gears? I am trying to stay period in my truck so I am trying to avoid newer columns.
My 1965 C-20 project
https://67-72chevytrucks.com/vboard/...d.php?t=835095
DoubleL is offline   Reply With Quote
Old 11-08-2012, 11:12 PM   #2
TxRat
TxRat's Avatar
Re: Anyone with a 700r4 column shift
mine is hooked up to the original column. park and reverse line up with the indicator letters. From there it doesn't line up exactly.
TxRat is offline   Reply With Quote
Old 11-08-2012, 11:26 PM   #3
DoubleL
DoubleL's Avatar
Can you shift into the lower gears okay?
Old 11-08-2012, 11:49 PM   #4
TxRat
TxRat's Avatar
Yes
Old 11-09-2012, 01:06 AM   #5
LT1 Burb
LT1 Burb's Avatar
I have a 72 tilt with a column and it works fine, used Lokar linkage from column to tranny.
LT1 Burb is offline   Reply With Quote
Old 11-09-2012, 09:45 AM   #6
kieth
kieth's Avatar
I have no indicators for the gears on my 700r4, it is not a problem with a tach and by feel one can tell what gear the truck is in........I would try a stock shifter column, the shifter shaft and flat plates that move the shifter linkage would probably work.... has anyone done that. ??
kieth is offline   Reply With Quote
Old 11-09-2012, 10:07 AM   #7
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
A new chrome bezel and indicator lens is available to replace the stock PRNDL.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-09-2012, 11:28 AM   #8
chevyguys
I Got it BAD!
chevyguys's Avatar
I have a stock 66 column and am using the Lokar rod linkage. I had to make one small bend to clear the firewall. The linkage is adjusted to it's longest length and just using the lower set screw. I also tacked the rod with a welder a few times to be sure it was solid. However, I don't think that was necessary. Park and drive line up, (drive is OD) and I am able to drop into 1st with no problem.
Build Thread: http://www.chevyguys.com
chevyguys is offline   Reply With Quote
Old 11-10-2012, 12:15 PM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
I got this column from a late 70's van. It was really a camper van and it even has a cruise control button if I decide to venture into that later on. It is a 3 speed tilt column and will shift the 700R4 easy. I had another in the truck for 4 years before scoring this one on a 25% off sale at pick and pull. Cost me a whole $28.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 11-10-2012, 03:07 PM   #10
lil_sahara450r
I have a stock auto column waiting to replace the 3 speed column. Good to know it will all work out with it. Honestly though, even in your daily drivers, does anybody still look at the indicator?? I know I dont... One down is reverse, three down is drive... its all in the feel
lil_sahara450r is offline   Reply With Quote
