Old 11-09-2012, 01:54 AM   #1
chevy 5.9
chevy 5.9's Avatar
front shackles
I need to raise the front of my truck to level it out
Can i use longer shackles and it still be safe? how long can i make theme?
84 chevy short box 4 inch suspension lift 3 inch body lift 5.9 cummins
chevy 5.9 is offline   Reply With Quote
Old 11-10-2012, 02:16 AM   #2
chevy 5.9
chevy 5.9's Avatar
Re: front shackles
no one knows?
Old 11-10-2012, 04:39 AM   #3
wwj75c30
wwj75c30's Avatar
Re: front shackles
i was told 2" is the most. i had them on my f250 but i didnt have A driveline hooked up so idk about if itll mess up your pininon angle
75 c30 silverado drw 454/th400hd d70 soon to have d60 up front
73 c20 custom deluxe sm465 14bff parts truck
wwj75c30 is offline   Reply With Quote
Old 11-10-2012, 04:58 AM   #4
MTCK
MTCK's Avatar
Re: front shackles
Read the tech notes at the bottom:
http://offroaddesign.com/catalog/hdshackles.htm
These will work:
http://offroaddesign.com/catalog/Zero%20Rates.htm
Off by more than an inch and you probably need different front springs.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-12-2012, 12:45 AM   #5
86454k30
86454k30's Avatar
Re: front shackles
Warrior products make shackles that give you an 1-1/2" of lift, so they are probably 3" longer than stock. Any more than that and it will screw up your caster for your frontend alignment.
86454k30 is offline   Reply With Quote
