Under 13 sec?
What does it take to make a 3700lb truck do under 13 sec in the 1/4 mile? This is what I'm going to try it with
http://67-72chevytrucks.com/vboard/s...d.php?t=553564 |
Re: Under 13 sec?
If it helps, when first out mine weighed 3900lbs, made 360ish rwhp unlocked conveter (similar to a th400) and the biggest issue was verter was way too tight, let alone gearing etc. It went 12.3x @ 109mph with a soft 1.89 60'
I think with an optimized combo, you could probably go high 12's with 300rwhp and 3,700lbs, but it would have to be really well set up. Posted via Mobile Device
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
Re: Under 13 sec?
Im hoping I have 330 to 350 rwhp and the weight is reduced up front by 100lbs.
Registered Truck Offender
Re: Under 13 sec?
Agreed, traction is the key and gearing. I was doing 12.40's in Tucson, 12.teens at Firebird with 3650 pounds and probably barely over a honest 425(crank) HP 383
But it has steamroller tires 33x17-15 DOT slicks and 5.43 gears, with a 4800 Midwest convertor. I was crossing at 6400-6600 at only 107-109MPH
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
mini truck racer
Re: Under 13 sec?
Im looking at 365 at sea level 90o/o and 87 degrees for 12.90 @ 3700
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Re: Under 13 sec?
Have a buddy that runs a stock suspension and drag radials w/355 with performer rpm set up runs low 13's and needs a converter bad.
NAME: TRAVIS TRUCK: BRUISER 71 C/10 SWB 3.5/5" drop 4.11 GEARS. F.A.S.T. BBC 408 496hp/479ft/lb JAKES 4L80E TCI TCU PTC 10.5" 2800 STALL My build thread: http://67-72chevytrucks.com/vboard/s...30#post5779530 |
