Brake Line Questions
Hey everyone, I am new to this forum and joined a few months ago. I have done a lot of reading here and it has definitely been helpful. I haven't posted anything yet but I'll show the work I've done in a new thread sometime soon.
But anyway, I have an 84 GMC Stepside that I have been restoring for the past couple of years. Finally I have been making good progress and got a nice frame that I had sandblasted and painted. I'm in the process of ordering brake lines, fuel lines, and bushings since I have easy access to everything frame related... Here's some questions I would appreciate being considered: Where is the factory location of the prop valve? I think I'm going to order from Inline Tube, and I'm assuming their brake lines are just like factory? I'm considering the brake booster/master cylinder as a kit from Performance Online. Included is the prop valve but I don't think it's in the factory location. I tried calling the other day but they didn't seem to answer my question. Here's the link: http://www.performanceonline.com/197...ter-Kit-19847/ Not sure if I should just order the proportioning valve separately. Thanks for reading this, had to get it off my mind. |
Re: Brake Line Questions
The proportioning valve is located on the very front crossmember (under the fan shroud).
Aftermarket Booster/MC/Prop kits are JUNK, Stick with the factory stuff. Inline tube is pretty good & will send line for the factory Prop. valve location. |
Ok thanks for the reply. Is there somewhere that I can get a new factory booster and master cylinder or would you recommend getting the factory units rebuilt?
If your Booster is bad, Just buy a reman one, A new MC will be readily available at any parts store....Do not buy a reman master cylinder.
And do you recommend getting a reman prop valve or Inline Tube makes their own...
Try your local Chevy dealer first, Have the VIN handy, At Least get a part # so you look online for one.
#7 | |
Unless I need it now I buy almost all my parts from rockauto.com sometimes you get a wholesaler close out on and item and get it dirt cheap but just about everything they have is priced very reasonable
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
Tags |
1500, 1984, c10, chevy, gmc |
