Old 06-06-2003, 04:24 PM   #1
BigRed
Question about Carb Install
I'm installing my new(er) carb tonight and am curious about something. Do you guys just crank it a couple times for the fuel to fill the bowls or do you use something else to prime with?
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 06-06-2003, 04:25 PM   #2
PHOENIX
Crank it.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 06-06-2003, 06:01 PM   #3
sbc350gearhead
sbc350gearhead's Avatar
If you are firing the engine for the first time, then fill the float bowls with a small funnel designed for the job (I use a small syringe). If not then crank it.....LOL
sbc350gearhead is offline   Reply With Quote
Old 06-06-2003, 06:24 PM   #4
78chevstepside
78chevstepside's Avatar
I always keep a spray bottle around for that function. Using a spray bottle will control how much you spray in. jay
78chevstepside is offline   Reply With Quote
Old 06-06-2003, 07:49 PM   #5
maineiac
I would have to go with the flow on this one and say crank it!
maineiac is offline   Reply With Quote
Old 06-09-2003, 10:41 PM   #6
jimfulco
Seems to me that cranking would get the oil flowing better before it fires up.
jimfulco is offline   Reply With Quote
Old 06-09-2003, 11:52 PM   #7
sbc350gearhead
There is virtually no oil flow until an engine fires up.
Old 06-10-2003, 07:44 AM   #8
maineiac
I would have to disagree with that . I have always been taught to pull the coil wire and crank the motor a few revs to get the oil to the top of the motor. In a new motor I always use a rod to pump up the oil before ever turning it over.
Steve
Old 06-10-2003, 08:08 AM   #9
Prerunner1982
Prerunner1982's Avatar
hell i maybe wrong here, but try putting a small about of fuel into the carb, then start it. it might help get the fuel in there quicker.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 06-10-2003, 08:23 AM   #10
BigRed
Thanks guys. The carb install was done on Friday. All is well. I just cranked it in short bursts. Didn't take too long.
Scott Shelbourne
Old 06-10-2003, 10:05 AM   #11
rockman20
"The dude abides"
rockman20's Avatar
The biggest thing you have to look out for when cranking a dry carb is this. If you have rebuilt the carb, did you put some lube on the accelerator pump seal?
The odds of this happening are sometimes small, but I have had it happen where I did a dry start, pumped the gas pedal a few times while cranking, and I ripped the seal on the accelerator pump. Just a caution.
On a Quad you can pour fuel down the pipe on top which will fill the bowl for you. When I do a rebuild, I like to put fuel in the bowl before I assemble the air horn.
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
