Old 02-20-2013, 11:30 PM   #1
rondog4416
rondog4416's Avatar
Wiring
I need to know where some wiring goes in engine compartment, there is a round plug with a light green and a dark green wire I think temp sensor ? The other is a dark green wire with two clips on the end ,any help would be great. Thanks Ron
rondog4416 is offline   Reply With Quote
Old 02-20-2013, 11:43 PM   #2
jbclassix
Junk Yartist
jbclassix's Avatar
Re: Wiring
Got any pictures? the temp sensor is a single wire (green I think) with a flat blade spade connector. The 2 wire with a round one may be reverse switch.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 02-21-2013, 01:22 AM   #3
rondog4416
rondog4416's Avatar
Re: Wiring
I will get pic's tomorrow thanks Ron
Old 02-21-2013, 11:13 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: Wiring
A little more info would be good too. A/C or no, year of truck, six or V-8, ect. The wiring can be different for every configuration...
LockDoc
Leon
Old 02-23-2013, 03:58 AM   #5
rondog4416
rondog4416's Avatar
Re: Wiring
It's a 1972 v-8 turbo-400 no a/c
Old 02-23-2013, 04:03 PM   #6
LockDoc
LockDoc's Avatar
Re: Wiring
How big is the round connector? Sounds like it might be the tail light connector but it would have four wires to it, Light Green, Dark Green, Yellow, and Brown and is about 1 1/8" in diameter.
The only single Dark Green wire I know of without A/C would be the temp sensor but I've never seen one with two clips on the end of it.
Like jbcassix mentioned, pictures would really help on this one.
LockDoc
Leon
Old 03-18-2013, 04:42 PM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Wiring
I thought the first pic might be the horn.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-18-2013, 10:47 PM   #8
jorgensensc
jorgensensc's Avatar
Re: Wiring
It may be the jumper for hi/lo horns. Mind has a green jumper between them.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-20-2013, 10:10 PM   #9
rondog4416
rondog4416's Avatar
Re: Wiring
Thanks guys that helps me out a lot !! Now to get back on it and go for a ride !!!!
Old 03-20-2013, 10:20 PM   #10
jorgensensc
Re: Wiring
Is the second one the turn signal wiring? The one that goes through the core support the the turn signal with pigtail connects to?
Old 03-22-2013, 11:19 PM   #11
Burb
Coordinator of Synchronicity
Burb's Avatar
Cool Re: Wiring
That was my thought for the second one ...the engine side for the front turn signals should have one on the other side as well
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 03-28-2013, 11:52 AM   #12
rondog4416
rondog4416's Avatar
Re: Wiring
in the second picture there is only one of these so im thinking temp sender thanks again for the help ron
Old 05-04-2013, 03:05 PM   #13
damianbryand
Re: Wiring
The second wire has a two prong connection that fits perfectly on the drivers side of a turbo 400. Not sure if thats where it goes but the exact length runs directly to the two prong (if you have one) connection on the tranny. I'm have the same wire running and I'm trying to figure it out as well.
damianbryand is offline   Reply With Quote
