Old 03-01-2013, 11:34 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Custom Autosound Speakers
Its time to change the "Harp" in my truck and I have a Sony AM/FM with a front USB and jack port so I can stuff my thumbdrive or hook to my IPad to it. For now until I get the gas tank out of the cab and install the back corner speaker brackets I need to get a better speaker in my dash. So I found that Custom Autosound has a speaker that fits in the original dash positon and has 2 tweeters from one speaker for stereo seperation. My question is, does anyone have one of these speakers in their truck and if so how happy/sad are you with the performance?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-02-2013, 12:36 AM   #2
c10monkey
c10monkey's Avatar
Re: Custom Autosound Speakers
I have wondered about this also ?????
1971 Chevrolet C10 Inflation Fighter
1994 C3500 Crew Cab Dually 454
c10monkey is offline   Reply With Quote
Old 03-02-2013, 04:53 PM   #3
Already Gone
Bump
Old 03-02-2013, 05:34 PM   #4
MidLifer
MidLifer's Avatar
Ive got one of those, its not bad but if you want to hear the music over road and pipe noise you're going to need more speakers. I'm getting ready to do kick panel speakers in mine.
However, for the in-dash speaker it's a good choice.
MidLifer is offline   Reply With Quote
Old 03-02-2013, 06:00 PM   #5
Already Gone
Thanks for the info. All I have now is door speakers and it didn't sound to bad with jsut those but the new stereo is much better and I figured for now one of those dual tweeter speakers in the dash would work great with the door speakers.
Old 08-10-2015, 08:37 PM   #6
SoChey72
SoChey72's Avatar
Did you have any problems mounting your speaker? I pulled out the old mono speaker and the one Custom Autosound sent me is a lot taller. I got it lined up with the bracket and it's a good couple inches from the opening on top and hangs down into where the radio goes. Pretty sure they sent me the a/c model instead of no a/c.
SoChey72 is offline   Reply With Quote
Old 03-02-2013, 07:14 PM   #7
72K20SUBN
72K20SUBN's Avatar
I have Custom Autosound deck with the dash speakers your asking about, as well as the kick panel speakers. My opinion, the sound is "OK" to "Good". Surely bettern than stock, but they aren't goint to blow you away.
I agree with Midlifer that the road noise will cause you to need a raise in volume when you're going down the highway.
I then installed the underseat speakers also made by Custom Auto (set has 8inch subs and tweets). This was a big improvement, even with no additionial amp, simply running them off the deck channels.
72K20SUBN:
- '72 Suburban K20
- '72 Cheyenne K20
- '71 Custom20 Deluxe 4x4
- '63 Pontiac Bonneville 2Dr HT
72K20SUBN is offline   Reply With Quote
Old 03-02-2013, 08:28 PM   #8
airdale94
airdale94's Avatar
I have these Pioneer underseat speakers hooked up to a Pioneer CD MP3 USB stereo and I'm pretty happy with them. I try to stay away from anything AutoSound.
http://www.amazon.com/Pioneer-TS-X20.../dp/B00009QOQB
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 12-26-2015, 12:14 AM   #9
72.4me
I like those under seat speakers but how do you mount them? I dont see any mounting brackets...
72.4me is offline   Reply With Quote
Old 03-02-2013, 09:26 PM   #10
GMtrucknut!!
GMtrucknut!!'s Avatar
I have the custom autosound kick panel speakers with the pioneer TS-X20 speakers under the seat and it sounds really good.
GMtrucknut!! is offline   Reply With Quote
Old 03-03-2013, 04:21 AM   #11
Mint68
Mint68's Avatar
I have heard good stuff about these guys, but haven't tried them yet.
http://www.turnswitch.com/speakers.htm
I had a custom auto sounds deck and had nothing but problems with it. I had to send it back twice for repairs, before just returning it. I would not purchase from them again.
Mint68 is offline   Reply With Quote
Old 03-03-2013, 01:41 PM   #12
72MARIO
72MARIO's Avatar
I had there deck in my truck for a couple of weeks It sucked. From sound quaility to the ability to tune in a station.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-10-2015, 09:04 PM   #13
EARNHARDT#3
EARNHARDT#3's Avatar
I just ordered a Retrosound Hermosa radio and their better dash speaker (they have 2 models). I plan on also getting a powered subwoofer. Either the one Retrosound sells or something else.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 12-25-2015, 01:21 PM   #14
70chevytruck
You have pics of install? Just got a custom auto sound unit and with all the negative reviews on this site I think I will return it and get something else.....suggestions?
70chevytruck
70chevytruck is offline   Reply With Quote
Old 12-25-2015, 03:45 PM   #15
tcrist
I put a Custom Auto Sound stereo in my 70 GMC, I had to make parts just for it to fit flush to the dash the way is should be (and the way the pictures show). I did put the dash speakers in and they are just ok. I ordered the kick panel speaker kits and was trying to make them fit correctly bud did not like the way they looked. I ended up putting box speakers under the seat. Not really a good idea either.
Anyway, the sound is just so-so. Better than a stock radio, which isn't saying much.
Not really much more that you can do without cutting up stuff to fit a real good quality stereo in there. At least a stereo that sounds as good as a newer car does these days.
If someone can recommend a real good stereo that fits correctly without cutting up a bunch of stuff and quality speakers that you don't have to add kick panels to, it would be a great add to this thread.
Terry
Soon to be retired and moving to Bristol, TN.
tcrist is offline   Reply With Quote
Old 12-25-2015, 07:38 PM   #16
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Custom Autosound Speakers
I made my own dash speaker panel and put Memphis gold speakers in it.
Here is a thread on making your own with mine and some others in it.
http://67-72chevytrucks.com/vboard/s...d.php?t=607314
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-26-2015, 03:50 AM   #17
swamp rat
swamp rat's Avatar
I think i have the same speaker you are referring, my honest opinion is its pretty tinny sounding, i think you would be better served by getting a couple smaller round speakers and make a home made bracket like yfs200p or Andy4639 did.
Here's a pic of the back of my speaker, its all the pic's i could find at the moment, the box package left a bit to be desired. there are 2 sets of speaker wires on ether side of the magnet. The mounting bracket was a bit flemzy too I had to make an additional bracket and attach the other side to the bolt extending down from the dash pad.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-26-2015, 08:02 AM   #18
GMtrucknut!!
Mine has been in the truck now for 5 years with no issues , but quality may have dropped since the purchase of it .
Old 12-26-2015, 10:28 AM   #19
redbaron
redbaron's Avatar
I put this system in our K10.
Stereo: Retro Sound Bluetooth, Iphone USB head unit, 5x7 Retro Sound dash speaker, Alpine 8" subs w/built in amps and Alpine 4" speakers mount in mid cab corners above gas tank. (Will not use the 5x7 speaker in the dash on next build with factory air...will use their 4x10 instead) Retro Sound recommends the 5x7 for factory air, but we had to cut the crap out of to fit.
This Stereo system sounds amazingly good and was able to do it with the stock gas tank still behind the seat.
Tried to paste the pictures of it from my K10 build thread but couldn't get them to do it. They are post #59 on page 3 of the thread.
Really like this stereo system and wouldn't change a thing. Tried Auto Sound stuff in the past and was very disappointed with them.
Mike
1972 C10 Cheyenne SWB Black Supercharged Project
1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175
1969 Camaro Protouring LS7 T-56 Project
redbaron is offline   Reply With Quote
