Old 05-05-2013, 11:38 PM   #1
Scott>72-GMC
Scott>72-GMC's Avatar
Square bore?
New to engines for the most part. Getting an edelbrock 1407 carb. Says square bore well what does this mean and what do I need to do. Thanks
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 05-05-2013, 11:43 PM   #2
Toxic Orange
Toxic Orange's Avatar
Re: Square bore?
Means all of the holes on the bottom of the carb are the same same size. Some have two larger and two smaller holes. What are you converting from? What intake manifold do you have?
Toxic Orange is offline   Reply With Quote
Old 05-05-2013, 11:45 PM   #3
Scott>72-GMC
Re: Square bore?
Really not for sure. Stock I believe at this point
Old 05-05-2013, 11:55 PM   #4
Toxic Orange
Re: Square bore?
May need others to chime in here, Quarajet to four barrel conversion. Looks like you may need an adapter if you are going to keep the stock manifold.
Part number 2696 from Edelbrock's webiste
Four-hole, Square-bore to Spread-bore Adapter (.850")
Mounts Edelbrock square-bore carbs to stock Quadrajet & Thermo-Quad manifolds. 2696
Old 05-06-2013, 12:02 AM   #5
Scott>72-GMC
Re: Square bore?
Ok. Thank you
Old 05-06-2013, 12:38 AM   #6
67c10rustbuket
67c10rustbuket's Avatar
Re: Square bore?
A factory intake should be a spread bore. Easiest way to explain is the spread bore has large "butterflies" on the secondaries errr its bigger at the rear where a square bore is symmetrical or equally square. Harder to explain than I thought. Perhaps a pic will do much better.
Pic 1 square bore
Pic 2 spread bore
There is an adapter but it only goes one way and I forget which way it adapts at the moment.. getting old sucks
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 05-06-2013, 09:38 AM   #7
jjhare
jjhare's Avatar
Re: Square bore?
This is what you would need.
http://www.summitracing.com/parts/mrg-1932/media/images
1972 C10 CST LWB
jjhare is offline   Reply With Quote
Old 05-06-2013, 09:39 AM   #8
Scott>72-GMC
Re: Square bore?
Thanks!
Old 05-06-2013, 12:20 PM   #9
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Square bore?
most adapters do go either way, from square to spread and vice versa. check Summit for adaptors
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
