Blazerless:-(
repainting a console
I am going to redo my console in my 1970 blazer. It isn't cracked, so it just needs a coat of black paint. Has anyone done this and does it take a certain kind of paint. Any advice welcome.
Thanks- Ken |
I used vinol? dye in a spray can, it's held up for years.
69 GMC 1 Ton Longhorn 37 Chevy Coupe |
Just shot the lid on my console with a test coat of SEM black vinyl dye. It looks really good but I bought the wrong black (Landau). Aside from the non glossy finish it looks great. As far as durability I don't know.
SKINNY TIRES RULE!
Has anyone tried the new spray paint that they have been advertising that is suppose to bond with plastic?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I did mine a while back.
Here's a link to all the pic's I took while restoreing it. here a couple teasers. Before ![]() stripped it down. ![]() painting it. ![]() The can on the left is what I used to paint the console.The middle can is what was used to strip it.I used the can on the right to paint it as well. ![]() done. ![]() ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 06-25-2003 at 06:17 AM. |
Blazerless:-(
thanks
That console looks great! Thanks for your pictures- thats just what I want mine to look like!
Hey guys how is the paint holding up on the consoles, I am getting ready to paint mine. Exactly what color and brand of paint looks closest to the original?
Merciless Butcher
SEM vinyl dye works great. Just make sure you follow the directions for prepping the plastic before you spray. I once dyed a vinyl covered steering wheel and it lasted for years. If you have one available to you, go to a professional auto paint supplier. They will tell you exactly how to do it and supply you with the correct materials. Spray it on in very light multiple coats rather than trying to get it all on at once. It always seems to turn out better that way.
Your Bought And Sold....I Got Your Soul! |
![]() Join Date: Oct 2001
DONT leave that paint stripper on long at all, it will melt the plastic!
trust me I tried some on a sample piece and it sofen it up,so dont leave it on long!!!!!!!
Things happen for a reason! |
The aircraft stripper I used I left on for 1/2 hr with no ill effect to the console.It worked pretty fast.
It's been maybe 6 months now and the SEM brand dye I used has held up fine.No peeling or chipping and the semi gloss finish is still semi-glossy:p
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
Robert Olson Transport
![]() Join Date: Oct 2002
whgat do you use to fill the cracks in the console?
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
The minor cracks in the cup holder were fixed with J.B. weld.
The MAJOR hole and crack you see were too big for J.B. weld so I got some galvinized sheet metal,cut it and bent it so it followed the contour of the bottom and inside of the console. I then rivited it in place sandwiching the orig. console bottom between the two sheets of metal. I then sprayed it with the SEM dye/paint. Here I've bent up the sheet meatal to conform to the bottom of the console. ![]() Bottom done. ![]() Here's the metal plate I cut up for the inside. ![]() I've painted it here with the SEM dye/paint.You can JUST see the rivits I used to attach the two metal sheets together. ![]()
Registered truck nut
I used duplicolor brand interior spray paint on my newer style console. My ol rotty likes to stand on it and his claws have done no damage. That's been several years ago. My only concern is that the plastic on these old consoles some times become brittle and scratch easily. When I did a set of door panels I had to sand them smooth first to get a good stick
MOUNT VERNON, WASH. STATE Need a part? Just PM me |
Bobby, is the landau black the color you used?
#15 |
Gee_Emm,ya,SEM Landau Black.
The first can of SEM Landau Black I got came out a REAL dull,almost flat color. I took it back to the autobody supply store I got it from and he said it should have a semi-gloss finish to it. He gave me a replacement can and you can see the results that can gave me.
