Old 01-12-2004, 12:44 AM   #1
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
The minor cracks in the cup holder were fixed with J.B. weld.
The MAJOR hole and crack you see were too big for J.B. weld so I got some galvinized sheet metal,cut it and bent it so it followed the contour of the bottom and inside of the console.
I then rivited it in place sandwiching the orig. console bottom between the two sheets of metal.
I then sprayed it with the SEM dye/paint.
Here I've bent up the sheet meatal to conform to the bottom of the console.
Bottom done.
Here's the metal plate I cut up for the inside.
I've painted it here with the SEM dye/paint.You can JUST see the rivits I used to attach the two metal sheets together.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
