Old 05-26-2013, 07:43 PM   #1
wittyandnitty
turn over but will not start
I have an 81 c10 with a 350 and it will turn over, plus it has fuel going in, but I won't start.
wittyandnitty is offline   Reply With Quote
Old 05-26-2013, 08:09 PM   #2
Sabaka454
Sabaka454's Avatar
Re: turn over but will not start
Did you check for spark? check the ignition system
Sabaka454 is offline   Reply With Quote
Old 05-26-2013, 08:17 PM   #3
wethepeople406
F.A.S.T.
Fuel
Air
Spark
Timing
start with the basics good luck
wethepeople406 is offline   Reply With Quote
Old 05-27-2013, 12:48 AM   #4
wittyandnitty
I think I made a mistake in the wiring of the starter. Are there any cables that go from the starter to the distributor
Old 05-27-2013, 10:59 AM   #5
Desert1957
Desert1957's Avatar
Yes, there is a "Battery Feed" its the other little terminal on the starter solenoid.
Desert
Desert1957 is offline   Reply With Quote
Old 05-27-2013, 11:07 AM   #6
Desert1957
Desert1957's Avatar
here is a pic
Old 05-27-2013, 11:51 AM   #7
wittyandnitty
Thank you very much. I kept reading that there is no wire going from the starter to distributor if its HEI? Is this true?
Old 05-27-2013, 01:16 PM   #8
Shyguy
Junior Member
Shyguy's Avatar
If it has a Hei distributor it gets its power from the ignition switch, if I remember right. On some trucks there is a 12 volt feed from the large positive post on the battery to the fuse block, but I am not sure which years.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-28-2013, 11:24 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
the HEI wire comes out of the harness,through the firewall plug
not right from the bat(needs on/off)
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
turnover, will not start
