Old 06-20-2013, 01:44 PM   #1
Clrussell
Clrussell's Avatar
62 c10 engine mounts
ive searched the forum and google and cannot find the mounts I need for my swap. im swapping a 5.3 into a 62 c10, it was a factory 6cyl truck with 3 on the tree, ive swapped in a 80s front crossmember also. I think ive seen a motor mount kit somewhere but I cant find em again.
thanks in advance
61 apache
Clrussell is offline   Reply With Quote
Old 06-20-2013, 02:53 PM   #2
Clyde65
Clyde65's Avatar
Re: 62 c10 engine mounts
I believe you can just use the mounts/perches from the 80's model trucks, I think they are called clam shell mounts.
On my 65 I used the POL tubular perches but really could have used the stockers if I really wanted to.
Oh and lets see some pix of this 62 beauty!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-20-2013, 03:18 PM   #3
Clrussell
Clrussell's Avatar
How do I post pics from my phone?
61 apache
Old 06-20-2013, 03:28 PM   #4
wgeyer88
Check out this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=584619
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 06-20-2013, 03:42 PM   #5
Clrussell
Clrussell's Avatar
So I need engine stands from the truck the crossmember came from and dirty dingo mounts? I had the 80 engine mounts at one time and they didnt look like they were going to be even close, maybe I had something wrong. But I can't find the engine stands I had so I guess I will go find some more if I need em?
61 apache
Old 06-20-2013, 03:49 PM   #6
wgeyer88
I'm not sure if the 80s trucks had different engine stands depending on engine type, but I know the V8 engine stands from the 80s trucks will work. Just get some dirty dingo adapters and the 80s clamshell engine mounts and you're set. The only thing you'd have to dig into is whether the stock transmission crossmember will work. I know on the 67-72 trucks you just have to move it back a little and it bolts right up.
Will
Old 06-20-2013, 03:50 PM   #7
wgeyer88
They 80s engine stands and mounts will look like this:
http://67-72chevytrucks.com/vboard//...1&d=1078173053
Will
Old 06-20-2013, 04:00 PM   #8
Clrussell
Clrussell's Avatar
I'll find some 80s stands and try em again! Thanks!
61 apache
Old 06-27-2013, 10:43 AM   #9
62-One-Ton
62-One-Ton's Avatar
The 80's stands are to tall for our 60-62 frames. They can be made to work with a 1" spacer under the frame side of the mount.
Project Change of Plans: http://67-72chevytrucks.com/vboard/s...d.php?t=513135
'62 C10 SWB
'03 Express Van 5.3l Dead (parting out and using motor)
'99 Silverado 4.8l 5 speed 4wd
62-One-Ton is offline   Reply With Quote
Old 06-27-2013, 11:04 AM   #10
Clrussell
Clrussell's Avatar
Thanks! I thought they were to tall but I havnt had time to check for sure
61 apache
